Results 1 to 14 of 14
Thread: Equipment not fastened to pad
    Aug 2014
    Near Montgomery, AL
    20
    My wife and I recently purchased a house with a pool. The pool was installed sometime after the house was built, I believe it is about 4-5 years old. I've been maintaining it using the TFP methods since we took posession of the house, and so far have had no problems.
    I recently discovered that the filter, the pump, and the booster pump for the Polaris are not fastened to the concrete pad. Should I be concerned about that? It would be simple to fasten the filter down with Tapcon screws, but the pumps would be more difficult, and I'd rather not go to the trouble of fastening everything down if it's not necessary.
    Here's a photo of the equipment:
    Russ
    11,500 gallon 14x28 IG vinyl pool, 3/4 HP FloPro Pump, CS200 cartridge filter, Polaris 280 with booster pump. Testing with Taylor K-2600 test kit and adding liquid chlorine with a Beta DR-2000 peristaltic pump.
    38,239
    Re: Equipment not fastened to pad
    Welcome to TFP!!!
    The equipment for both of my pools was not attached to the pad. Seems pretty common not to be.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    No need to fasten down the equipment. Its not going to move around and if you have to replace any of it one day the holes probably would not match up. I am curious about the single ball valve to shut off the flow of water. Does that line go to a main drain?
    Love TFP? Become a
    TFP Supporter!
    Aug 2014
    Near Montgomery, AL
    20
    Thanks for the replies, that's pretty much what I thought. As long as gravity works, the equipment is not going anywhere.
    Yes, the line with the ball valve goes to the main drains. I determined that experimentally when I was draining water to reduce the CYA level. Fortunately there is a valve before the cartridge filter that will divert the flow to a waste port, that made the drain easy, but it's tough to drain below the bottom of the skimmer.
    Jul 2009
    Houston, Texas
    9,376
    I guess so, since you can't shut off flow from the skimmer. You could use a plug in the skimmer and just draw from the main drain if you ever need to drain below the skimmer again. If you ever decide to re-plumb the equipment pad, be sure and add a pool valve to the skimmer and main drain lines. It'll make life a little bit easier.
    Love TFP? Become a
    TFP Supporter!
    happyheathen's Avatar
    Sacramento CA
    225
    I managed to drain the entire pool using the filtration pump - I lucked out and had an old (glass) pot lid which fit the seal ring around the bottom of skimmer. Some plumber's putty and dead weights forced the pump to draw up from the main - I could see the water rushing out of one hole and down the other.
    Couldn't leave it unattended - it would eventually suck in enough putty to break the seal - a quick shutoff and application of more putty, and back in business.
    I wonder if the plates sold for sealing the skimmer for use with a vacuum hose could be adapted (plugged) to get the same effect?
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    Jul 2013
    Lelystad, The Netherlands
    60
    Sorry for hijacking this post ..
    The picture of your installation seems quite common for USA pools, but I have never seen such in The Netherlands. Would you explain to me what all the equipment is? The large filter tank is that a colon with a large white plastic filter in it? Or is that what they call a DE filter?
    Why do you need 2 pumps? You have 11500 gallons of water, that's 43500 liters, same volume as I have. So you could pump that with just 1 pump?
    I'm not criticising, only curious about other use of equipment I'm unfamiliar with.
    40000 liter in ground vinyl pool with SWG : http://www.troublefreepool.com/threa...he-Netherlands
    Aug 2014
    Near Montgomery, AL
    20
    Quote Originally Posted by happyheathen View Post
    Since my first drain stopped at the bottom of the skimmer, I didn't replace enough water to get the CYA where I wanted it. There are two ports on the bottom of my skimmer, one is plugged, and the other has a little plastic door that pivots and can be set to cover all or some of the port. I didn't notice it until the skimmer was sucking air the first time, and it was too late, the door wouldn't seal. The second time, I closed that door when I started the drain, and it sealed and allowed me to drain below the skimmer.
    I didn't think about the vacuum hose plate...there's a vacuum in the garage that connects to the skimmer, but I've never used it. The notebook the previous owner left with info about the pool said to use it after putting in all of the pool store chemicals to kill the algae in the water, but I've never had to do that, thanks to this site.
    Aug 2014
    Near Montgomery, AL
    20
    Quote Originally Posted by koffie View Post
    Not a problem...
    The pump on the left is the main pump that circulates the water through the filter. The large filter tank is a cartridge filter like you describe with a large white pleated filter cartridge in it. The second pump on the right is the booster pump for the Polaris pressure side cleaner. It is only turned on when the cleaner is in use and provides high pressure water to a return that has a special fitting to connect to the cleaner.
    Jul 2009
    Houston, Texas
    9,376
    You could also connect a vacuum to the skimmer and let it sit on the floor of the pool and draw from there as well.
    Love TFP? Become a
    TFP Supporter!
    Jul 2013
    60
    Quote Originally Posted by russenterprises View Post
    Not a problem...
    Thank you for answering. Now I understad
    Jul 2013
    60
    Just an other questioned popped up : Wy doe I see all the equipment placed out in the open? I couldn;t think of placing my equipemnt (and electra) in the open aire.
    Nov 2011
    Sabina, Italy
    39
    Just a quick note about the original question, it's generally a good idea to firmly fix pumps. They won't go anywhere (usually) but they will always twist a bit when switching on and off (torque reaction), which will eventually loosen or crack any rigid pipework attached to them, not that big a deal with plastic plumbing, but worth noting that it is a primary cause of leaks. Pumps that have rubber 'feet' or mountings to absorb NVH should always have special flexible couplings. Yours will probably be fine for years, my experience is that it will then fail while you are on vacation or an hour before all your friends turn up to swim and BBQ...
    160,000 litres (42,000 U.S. galls) 15 x 7 metres (53 x 23 feet) hybrid. Concrete floor, glass fibre walls. 1.5 HP Tifon pump, 150 kg (330lb) sand filter. Free form shape (not a straight edge in sight) 30 years old.
    wjr75's Avatar
    Jun 2013
    IL
    836
    All of my equipment is bolted to the pad.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
