Thread: Water leak at exterior bottom of skimmer
    May 2014
    Trenton, NJ
    24
    Hi, I had my above ground pool installed in May and have not had any issues. Today, I was cleaning the filter basket and I noticed greenish water that lead from underneath the exterior portion of the skimmer and led to the stone on the ground underneath it.
    I attached a couple pictures.
    I guess there is a slow leak at the bottom of the skimmer on the outside. Is this something that I should be concerned with. My pool was installed in May, so I'm guessing if there is an issue, it should be covered under warranty at this point. Thanks for the help.
    FYI pool water clear and doesn't appear to be losing much water from pool.
    15'x26' above ground pool installed on 5/10/14, 1 hp -Hayward pro series sand filter (Model # S166T92STL), Hayward Vari-Flow valve (Model # SP0714T1), Hayward Power-Flo Matrix pump (Model # SP1592TLFP). TF100 test kit. Diver Dave automatic vacuum.
    38,252
    Re: Water leak at exterior bottom of skimmer
    If it is under warranty, have them fix it. Might be as simple as verifying the screws are snug.
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    I had a similar issue. Had a tiny. I mean tiny pin hole above my return valve. It was filling up between the wall and liner. The skimmer was where it found a way out. Try the simple things first like loose screws, weir, etc. I'd call and have them come out and look at it ASAP.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
