Thread: Dual Speed Pump Misbehaving
    Aug 2014
    Pasadena, MD
    3
    Hi all. I installed a 2.5 HP dual speed motor to my WhisperFlo pump last year. It's controlled by a Jandy Aqualink system (rev M I believe) with Aqualink One Touch RS Remote. The Aqualink is programmed to run high speed for 1 hour and then switch to low speed for 6 hours. Last week, the motor began toggling between high and low speed every couple of seconds. Constantly switching back and forth. I try to override with the remote and it doesn't stop. I switch to spa and it doesn't stop. However, if I set the system to Service and use the manual controls at the pump, the issue goes away.
    My assumption is that the problem is with my Touch RS Remote. It is old and beat up. Before I spend $500 on a new one, I thought I would ask for second opinions. Could it be the high/low relay or a short somewhere else?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Dual Speed Pump Misbehaving
    When the motor switches from high to low, is it reflected on the controller readout somewhere?
    If you hadn't told me it works when toggling manually, I would have suspected a bad centrifugal switch. But given, you can control it manually, it must be the controller but then is should reflect the speed change in the readout. If not, then yes, I would suspect the high/low relay as well but then I would expect that to still misbehave even in manual mode.
    Mark
    Aug 2014
    Pasadena, MD
    3
    Yes, I can witness the toggling on the display of the controller remote. Filter Pump kicks on, then Low Speed, then Filter Pump, over and over again. Must be the remote. Thanks mas985!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Could it be a bad/worn relay on the aqualink?
