Thread: FC down to 1.5 while away
    Jul 2013
    Waxahachie, Tx.
    446
    Well, I come home after 3 weeks work, the wife says she has barely had time to sleep, let alone test the water.
    He last test was on 7-31-14 at 930 AM after the pump had been on for 1 1/2 hours
    FC 3
    CC 0
    TA 120
    PH 7.8
    CYA 60
    Temp 80
    Salt 3500
    water was crystal clear
    My first test when I got home on 8-12-14 at 9AM, pump had been on for 1 hour
    FC 1.5
    CC 0
    TA 120
    PH 7.4
    CYA 60
    Temp 84
    Salt 3400
    Tested FC again at 330PM 2.5 and out of the return jets with cell producing it was 4.0
    8-14-14 at 1PM
    FC 3, I have bumped my output up from 50 to 60%
    Will test again at the end of my pump run time to see where I am at.
    Suggestions and comments are always welcome.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,097
    Re: FC down to 1.5 while away
    What does the water look like?
    Jul 2013
    Waxahachie, Tx.
    446
    Crystal clear. We did have rain and 100 degrees while I was away
    Jul 2011
    Eastern Ohio
    7,097
    Bump your FC up to 8 and go swimming. IF you're worried, an OCLT will tell if anything is growing. Sounds like you're all good however.
    Jul 2013
    Waxahachie, Tx.
    446
    I did add 3 oz of diclor. Did not have any bleach. But by pool math i should b ok. My ph will come back naturally. And the little bit cya it adds is not an issue.since the install in April have only tweaked the swg and added some stabilizer twice. Very easy to take care of
