Thread: Isn't 12% chlorine 88% NOT chlorine?
    Aug 2014
    Central Ontario, Canada
    2
    Hello, TFP peeps! Long time lurker here with a question regarding chlorine math!
    I did try to find the answer by continuing to lurk but the particulars are very specific and I struggled with search terms which would successfully extract this content from every other post on the forum.
    So:
    Let's arbitrarily take a 20,000 gal pool. Measuring in "parts per million," we get:
    20,000 / 1,000,000 = 0.2 gal = 25.6 oz = 1 ppm.
    So "1 ppm" of "anything" in this pool is 0.2 gal (25.6 oz) of that substance.
    Logic would then suggest, to raise the chlorine content of this hypothetical pool from "x" ppm to "x+1" ppm, I need 25.6 oz of chlorine. The pool calculator sort of agrees, but that's where the subject line confuses me - 6% vs. 12% vs. 100% chlorine. Unless... when we say "+1 ppm of chlorine" we actually mean "+1 ppm of [12%] chlorine (plus 1 ppm of 88% more water... )"?
    Pool calculator says:
    To go from X to X+1 ppm FC, add 41 oz of 6% "bleach" or 21 oz of 12%.
    (somewhere around 9.7% bleach will give me the 25.6 oz mathematical target)
    So I guess that's my question - when we say "ppm chlorine" in relation to FC, it would seem we actually mean "ppm [~12%] chlorine"?
    True / False?
    Thanks!
    38,271
    Re: Isn't 12% chlorine 88% NOT chlorine?
    False. We mean 1 ppm of FC. Does not matter the source of the chlorine. Is there a reason you doubt the calculator?
    Welcome to TFP!
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Well your math is wrong to begin with. One millionth of 20,000 gallons is 2.56 ounces not 25.6 ounces. Divide 2.56 by 0.12 (if you are using 12% chlorine), and you wind up with 21 ounces of liquid chlorine. When you want to add 1 ppm, the amount will differ depending on the concentration of the chlorine.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Aug 2014
    2
    Oops. Yes - 0.02 gal not 0.2 gal. Ok, got that. Missed a zero somewhere!
    I see now the part I was missing in the math as well - coincidentally being off by 10 (missing a zero) gave me 25.6 vs. 21 which made me think they were related; if I had properly calculated 2.56oz I would have better known I was still missing a step completely. Dividing 2.56 by 0.12 was entirely missing and now makes sense for the 21oz reply from the calculator! Thanks!
    And for jblizzle - Hi. No, I have every confidence in the calculator, in fact it is quite brilliant. I was trying to understand what it was telling me, and the difference between the various %'s of chlorine available and how that affects the results. I am currently waiting for delivery of a chlorine pump and am trying to properly understand my options, i.e. if I need "x"ppm of extra chlorine, how much at 6% and how much at 12% would that be and why. The math (and math correction) from sargent helped fix that.
    Next step - get a reliable tester kit (in Canada... boo) and start tracking my chlorine consumption so I know how much to add!
    Thanks guys!
    38,271
    Well, you would need twice as much 6% as 12% for the same ppm rise
    Yeah, you guys up north are kind of limited in your test options
