Results 1 to 13 of 13
Thread: Muriatic Acid - Need to lower PH
    May 2014
    Pflugerville, TX
    148
    I'm just a beginner, but I've read you can get MA at the hardware store.
    Home Depot it closest to me, though I see a lot of mention of Crown from Lowes.
    This from Home Depot (if it works) is 2 gallons for under $11. A better deal than lowes and it seems to be 20 Baume (31.45%)
    http://www.homedepot.com/p/Smart-2x1...specifications
    Anyone see any problems using this?
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Muriatic Acid - Need to lower PH
    That will work just fine. That's the concentrated stuff which is the most economical but use caution when handling and adding to pool.
    Isolated Spa - 345 Gallons
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Mindflux View Post
    Nope - no problems, that is the stuff you want. At that price I'll have to go by HD as I normally use Lowes.
    Just remember, this is strong stuff. I don't wear gloves, but I do make sure I have glasses on. I open the bottle after I am kneeling next to the pool and partially submerge the bottle in the pool and pour from that position. This reduces the possibility of splashing on my clothes or the pool deck. I also don't measure. I guesstimate pour. I can always make it up tomorrow if I'm a little light on the MA. It has a very strong odor so I open and close at arms length and only leave it uncapped while pouring.
    Support the site
    38,251
    If it is not half strength then that is a decent price and fine to use.
    May 2014
    Pflugerville, TX
    148
    How would you tell? The bottle label suggests it's 31.45% which seems like the potent stuff.
    Quote Originally Posted by tim5055 View Post
    I'll keep this in mind. Seems like a good way to lose a full jug in a pool though but I understand the precaution.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    I hold my breath the whole time I have 31.45 open. Glasses, gloves, measuring cup. Strong stuff.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by peterdaly View Post
    I agree! That is why I skip the measuring cup. Just one extra step while it is open to allow for spills.
    Support the site
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    I use these
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    I use this and it works fine. When my pH is high I pour in a bit and the next day my pH is about where pool math says it should be.
    Just to reinforce the others: this is strong, nasty stuff in concentrated form. Please take precautions and wear your safety gear while dealing with it. Gloves and glasses at a minimum at my pool.
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    Apr 2013
    Sacramento, CA
    2,769
    You should also store you MA well away from your chlorine. Never mix them it results in chlorine gas. I buy my MA at HD too.
    May 2014
    Pflugerville, TX
    148
    Quote Originally Posted by gwegan View Post
    I have a SWG, so I don't think that'll be a problem. Thanks for the tip though!
    Quote Originally Posted by astronaut888 View Post
    I use these
    Getting an attractive women to do it for you. Very smart.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by SwimAustin View Post
    I tried, the wive vetoed the pool girl idea....
    Support the site
