Results 1 to 8 of 8
Thread: Please recommend automation system
    Nov 2013
    Fort Worth, TX
    114
    Hi,
    I have a pool/spa combination and am getting ready to add a Stenner pump based on all the reviews I have read on this site. I'd like to now add automation as my pool equipment is not very close to the pool/spa and I'm getting tired of having to turn on and adjust valves, temperature, and pumps before and after I jump into the spa.
    I'd like the automation to control the following:
    1) Main pump - single speed 2.5HP
    2) Polaris 280 with booster pump
    3) Raypak RP2100 propane heater
    4) Waterfall (not crucial but nice)
    5) Stenner pump - to be added in near future
    To go from pool to spa and back, I have just two valves to adjust.
    So, I guess I need 5 circuits and two valve actuators.
    I need to have remote capability as the pool equipment is not located conveniently by the pool. I want to be able to adjust and monitor pool/spa temperature (ambient would be nice as well)
    I would also like to be able to install, program, change, and maintain this on my own. I'm an engineer, so I do have some mechanical and electrical knowledge.
    Any suggestions?
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    38,268
    Re: Please recommend automation system
    How is the waterfall controlled?
    I am not seeing 5 circuits. I only see 3 relays required for the 2 pumps and the Stenner.
    Nov 2013
    Fort Worth, TX
    114
    The waterfall is controlled with a simple switch located on the patio near the pool/spa, hence this is not a top priority. It does, however, have a separate pump located with the rest of the pool equipment. Wouldn't this require a relay of its own? Also, what about the heater, I assume it too would require its own relay?
    38,268
    I was trying to learn if it had a pump or a valve. A pump would need a relay. You should consider a 2 speed pump eventually, which would require another relay.
    38,268
    No relay for the heater.
    Nov 2013
    Fort Worth, TX
    114
    I assume you mean a "2 speed pump" for the main pump to replace the single speed 2.5HP motor? If so, I agree. This motor was replaced under a home warranty just last summer, so I suspect it will last for awhile! I doubt I'd see a good payback from a 2 speed motor based on just the energy consumption difference between the two pumps. Currently, since I'm using bleach to chlorinate the pool, I only run the pump about 5 hours per day and that seems to be enough.
    38,268
    You could easily see a 50% reduction in power consumption, the $ depends on your power cost.
    I would also consider replacing the booster pressure cleaner.
    Nov 2013
    Fort Worth, TX
    114
    I found this and I think it will do what I need. Other automation systems are twice the price!
    http://www.backyardpoolsuperstore.co...rs_p_7984.html
    Comments?
