Thread: SWG for Big Pool in Apartment Block
    Mar 2011
    Monaco
    23
    Hello All,
    its been a while since I have been active on the forum and I know from the past that this is the best place to get information on pool stuff. I have a posting in Turkey and we have a beautiful pool of around 600M3 (160,000 gal) in our apart block. In my home I have a SWG and really swear by the softness and quality of the water.
    At the moment the workers everyday lug between 5 and 10 drums of chlorine into the pool room - which gets put into the dosing unit. Whilst the quality of the water is nice - it is not as good as SWG.
    During the winter I am considering installing a SWG system.
    Does anybody know any units capable of this size available on the market? Approx. cost? I would be interested in doing an investigation.
    Again thanks for all the wonderful help from this site.
    Jonathan
    IG Concrete, tiles and plaster. Pool size: 100M3 (26,417 US Gallons) Sand/Gravel Filter Astor 99 cross section 0.44M2 (4.74 sq. ft.) holds 290 kg (639 lbs) sand/gravel also sometimes with some DE inside. Pacific Sel SWG, Pacific PH Automatic Doser.
    Pump size 1.6HP 24M3/hour (6340 US gal/hour)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SWG for Big Pool in Apartment Block
    I'm sorry I don't know, but would be interested in the answer. We deal with residential pools mostly, so we can't always answer these types of questions Im sorry to say. Hopefully we find out here.
    Essential Links:
    Jul 2014
    Peoria, IL
    389
    If you can split off the return line into some type of manifold then could you not use a few smaller units? May impede flow to significantly, not sure. But have see that before. I am sure a large enough commercial unit is available somewhere, but where and cost??
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    JoshU's Avatar
    New Orleans, LA
    543
    There are a handful of companies that manufacturer commercial salt chlorine generators. Sizing commercial projects is much different from residential pools. With commercial pools bather load, water temperature, water features, etc. all are considered in addition to how many gallons the pool is. Consulting with a professional distributor who can help determine what size system is needed is key.
    We are unable to distribute our products outside of the US however if you provide an e-mail address to me I can forward your info along to a company that handles these types of products internationally so they could help you determine what is needed.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Mar 2011
    Monaco
    23
    Thanks to everybody for replying - PM sent to Josh - average bathers 60 per day - pool water temperature in summer usually around 30C (86F) + there is a waterfall about 10M long and the water falls about 1.5M
    thanks again,
    Jonathan
