Thread: Solar controller with high/low relay option for 2 speed motor
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello All,
    Is there a stock solar controller that offers a 2-speed relay for high/low pump operations. When solar is called for motor switches to high, no solar, low speed.
    Doing some ground work, thinking about adding solar.
    Re: Solar controller with high/low relay option for 2 speed motor
    Many of the automation systems will do that, but I haven't seen a dedicated solar controller that does. Several of the solar controllers could be easily modified, just replace the SPST relay with a SPDT relay. But that does require locating a compatible relay.
    38,548
    The SolarTouch can have a dual speed relay added ... although a little more than a basic solar controller, but less than the full automation systems.
