Thread: My diamondbrite surface has always been rough
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    My diamondbrite surface has always been rough since day one. its like a medium coarse sandpaper. I brushed like crazy for the first year and it never made any difference. my pH and Calcium levels are always right on target. When I asked the builder last year he told me it was normal for diamondbrite because of the exposed aggregate.
    is this right? does draining and acid washing will make the surface smooth? I don't think they ever acid washed when the plaster was first done...
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: My diamondbrite surface has always been rough
    I suppose it's what you consider rough. What you describe does sound excessive if it truly is like coarse SP.
    Essential Links:
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Yes I'm pretty sure it's excessive. So, is anything can be done?
    Aug 2010
    Dallas, TX
    4,052
    I have a similar surface, and the plaster company told me the surface can be polished. You might call SGM and see what they say.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Ok thanks, is your surface rough as well?
