Thread: Greenish tint
    Greenish tint
    My water was perfect but I noticed my cartridge filter pressure was high so I needed to clean the filters. They were filthy. So bad I was surprised my water was clear.
    I cleaned them and one day later my water had a dusty look and green tint.
    Several days later still Greenish.
    I keep my fc low.
    Current values:
    FC 3
    CC 0
    PH 7
    CH 480 ( high for me)
    TA 110
    CYA 120
    Suggestions? I use granule shock and tabs.
    Bill
    24k gallon; chlorine; gunite with stone scape mini;
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Greenish tint
    Welcome! You have come to the right place to fix your pool and keep it clear!
    I am going to give you some links to read through.
    http://www.troublefreepool.com/conte...etting-started
    These will get you started.
    I would also like you to think about doing your own testing. There has been MANY people that use their local pool store for their testing. I am one of them with my last pool. In the end my pool ended up such a mess that the liner "rotted" out even with water in it from listening to the pool store
    Pool stores "free" testing is not so free nor is it accurate.
    The test kits we all use are listed in my siggy below. Since your pool is already green you will want to get the TF100 EL as you are going to need to SLAM your pool. Here is the SLAM link
    http://www.troublefreepool.com/conte...ntain-shocking
    Let us know what you decide to do.
    Kim
