Results 1 to 11 of 11
Thread: Couple Chlorine Questions
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    Here are some questions I've been wondering, but can't find an answer to:
    1. Pool servicemen visit pools weekly, right? How do they keep the pool from going green without adding chlorine daily?
    2. In the TF-100, it comes with an OTO along with the FAS-DPD. How often do you test with the FAS-DPD?
    Bobby (my pool)
    18,000 gallon in ground/white plaster
    Flotec pump/Aquatech MYB100 single cartridge filter - runs 6 hours/day in evening during summer
    Aug 2010
    Dallas, TX
    4,052
    Re: Couple Chlorine Questions
    Pool guys usually dump puck(s) in the skimmer. They don't care if your CYA goes sky high.
    I test with FAS/DPD about once per week.
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by ThinkPad View Post
    In reverse order:
    2. Daily -- I rarely use the OTO that comes alongside the pH test. Not very accurate or easy to read.
    1. Magic beans
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    48
    The pucks will keep the pool from getting green. As long as you're willing to keep increasing the amount you drop in
    When I first started caring for my pool using the TFP method I tested with FAS-DPD every day or every other day. This was in effort to understand exactly what my pool demanded. After the first season I could see obvious patterns depending on usage, weather, solar cover on or off, etc. Now I know my pool well enough to only test once a week or less using the FAS-DPD.
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    So no FAS every day? That's probably why the TF-100 came with an OTO, for everyday testing. I was thinking about doing FAS-DPD weekly, and OTO daily, but I may not even do daily tests.
    Good to hear what others are doing.
    Bobby (my pool)
    26venus's Avatar
    Jul 2013
    48
    I should add that I maintain a CYA level of 30 which requires a chlorine level within the range of the OTO tester. If your CYA is at a level that requires a chlorine level higher than 5 it would be wise to test with the FAS-DPD more often than weekly
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Operating with CYA of 30-50 it's pretty easy with the OTO for daily testing. If it's 5 or "more yellow" no need to add. If it's less yellow than 5 it's a ballpark of whether it's 3 or 3.5 or 4 so I'll bump it up 2-3 FC.
    Saturday is FAS-DPD day.
    Isolated Spa - 345 Gallons
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    Quote Originally Posted by 26venus View Post
    You can tell by how dark of a yellow it is. I can usually tell when it is 6 or 7 ppm.
    Bobby (my pool)
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I have never used the OTO chlorine test due to my sky high CYA and stupid amounts of FC I had to keep. I've finally beaten the CYA down to a level that I can almost use the OTO test, but now the Sample Sizer and SpeedStir Magnetic Stirrer are so fun to use I just end up doing the FAS/DPD. Now, I admit that with my Stenner pump I generally only test every other day.
    As other have said, most pool companies don't understand or care about your CYA level.
    Support the site
    May 2011
    Los Angeles, CA
    228
    I find it hard to match colors and much easier to determine when the pink disappears. So I hardly ever use the OTO test.
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    Oct 2013
    Chapin, SC
    1,141
    Yup! Me too!! Ditto the SpeedStir!!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
