Results 1 to 9 of 9
Thread: Empty pump skimmer basket
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Sooo I go to turn the pump in this afternoon and my pump skimmer basket is dry and the concrete pad it sits on is wet. Anyone???
    Lynzizzle
    IG, 25k gal (est.), concrete free form, Hayward S-244T 300lb sand filter,
    well water, Pump: AO Smith 3/4 hp, VSpd: Unknown, Pool Age: Unknown
    Welcome to our OOL. Notice there's no "P" in it?
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Re: Empty pump skimmer basket
    Edit: also just added DE over the weekend and my pressure is up. Could that be the cause of that? I noticed that after I filled the basket and turned the pump back on that my filter was leaking from the valve on top, however, it wasn't screwed on tightly ...
    Lynzizzle
    Jul 2011
    Perrysburg, OH
    88
    A leak from the top of the filter shouldn't drain your pump basket. If it was completely drained I'd say most likely cause is a bad seal on the impeller.
    16 x 32 inground vinyl pool (21000 gallons) (new liner installed 2014)
    Hayward max flo pump w/ 1 HP AO Smith motor (new motor 2014)
    Hayward C1200 cartridge filter (new 2014)
    Hayward H150 heater
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    How do I fix that?
    Lynzizzle
    May 2011
    Los Angeles, CA
    228
    Is there a drain nut on your pump? It could be loose and leaking. I have a drain nut on the basket housing on the pentair intelliflo VS.
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    There is, yes. Weird thing is is that I refilled the basket and restarted the pump and haven't had an issue since. I'll check it
    Lynzizzle
    May 2011
    Los Angeles, CA
    228
    If it is leaking it will leak when the pump is off. It is on suction side of the pump so while the pump runs it will be sucking in air rather than leaking water. But as soon as the pump goes off, it will start leaking water.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    +1 one with Suley. It won't leak while running on the suction side.
    That loose fitting on top of the filter will cause a leak with the pump running and cause the wet area around the pump on the pad. It will also allow the waters weight to suck in air and let the water run back to the pool out of the filter and out of the pump basket.
    Was the pump basket empty all the way or only down to the bottom of the inlet line ?? If all the way down it's likely the plastic plug at the base of the basket is leaking. Look for more than one plug, mine has two. They should have teflon tape or pipe dope on them to help seal them.
    If it's only down a couple inches in the pumps basket, to the inlet pipe it's likely the loose fitting on the top of the filter caused the water to run back to the pool.
    Solar Blanket, Well Water, Borax Added. 68
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    No it was dry ... All is well again. Confused!
    Lynzizzle
