Results 1 to 11 of 11
Thread: Coping before tile....HELP!
    Apr 2014
    League City, TX
    22
    Our PB neglected to ensure that the waterline tile was ordered in time, so now we don't have any available and have to wait a week. The issue is: the pool is at tile and coping stage. Most pool builds I have seen have the waterline tile installed before coping, but now our PB wants to install coping now and then install tile.
    Tile is 2"x12" glass tile with a brick pattern and the coping is travertine 12"x24"x2"thick.
    Why is tile typically installed first and what are the negatives to reversing the process?
    Thanks in advance!
    T8er
    Nov 2013
    Miami, FL
    348
    Re: Coping before tile....HELP!
    Our coping was installed before the waterline tile. I didn't realize it was typically done in the reverse order. Maybe it doesn't matter?
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
    bulldogz400's Avatar
    Jun 2014
    Las Vegas
    128
    As it was explained to me by the tile guy:
    The tile setters are the ones who ensure the leveling is correct. Thus, they needed to tile the waterline prior to doing the cantilever coping.
    It then had to be reversed for the tile guys to finish as they needed the coping in place to correctly install the stone around the perimeter of the spa. The coping served as a "ceiling" so they could butt the stone as close as possible to it. For me, the order is tile, decking, then finish the tile.
    IG gunite 32 x 18 on a bachelor budget! Click Here To See
    Apr 2013
    Sacramento, CA
    2,769
    Bulldog has it right. The tile guys are the ones responsible for the final finish elevation of the pool. They bring the bond beam to within 1/4 inch level. Then they install the tile. The Coping is put over that. If its cantalever coping then generally it slides on top of the bond beam. So the bond Beam has to be at the correct elevation to make sure the concrete is poured correctly and the mastic seal is between the concrete and tile.
    You can do it in the reverse. But you need to make sure thew bond beam is level all around the pool to whatever the spec is. In most cases its 1/4 inch. You also need to make sure that the mastic can be placed between the coping and the tile.
    Northrider23's Avatar
    Sep 2013
    South Florida
    175
    Our tile guys were the same ones who also installed the coping. But I do remember them marking were the tile would go and leveling the coping first and then installing the tiles.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Our coping was formed and poured before the tile and stacked stone were installed. Maybe it's off a 1/4 inch... but I will never know unless I take my laser level swimming with me.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to the forum T8er
    Solar Blanket, Well Water, Borax Added. 76
    Jan 2014
    SE Louisiana
    147
    The order doesn't matter. The only important thing is that whichever is first is set level. With glass, I personally feel that coping first is easier because the glass bends and flops all over the place when you install it (unlike a 6x6 solid piece of tile which stands upright). The guys who sold me the glass said they prefer coping first also. But again, it doesn't matter ... The ability of your installer(s) is all that matters.
    Jun 2011
    Carlsbad, NM
    172
    It all depends on the coping and tile type. Poured coping is usually done before tile. If you have stone coping, tile is first. In my case (flagstone with glass mosaic), the only way to go is tile first.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    May 2014
    Lewisville, TX
    29
    My coping was done before the tile. Everything looks level and they didn't seem to have any issues doing it in that order.
    Apr 2014
    League City, TX
    22
    Thanks all.
    My pool has an infinity edge and I have a below water-level (hidden) spa, so if it isn't all level, we are going to see it pretty quickly, since the water will definitely be level!
