Thread: What is it?
    May 2014
    Clinton,Iowa
    42
    Angry What is it?
    I shocked my pool Friday night FC reading on Saturday were 10.8 and came home today after being on vacation to what I belive is algea but not sure. It is kind of clearish and yellow. Here are my readings:
    FC=2.8
    CC=.4
    TA=70
    CH=30
    CYA=80
    PH=7
    Pool Temp=78
    How can I be losing so much chlorine in 2 days when the stabalizer is so high? My filter probably needs to be replaced but at $100 a shot and the season almost over I think I am going to hold off. Next year we are getting a sand filter. My pic won't download.
    28' Above Ground Pool, 20,000 Gallons
    Sand Filter"
    Model #AC16985
    Pool built in July 2012
    Clinton, Iowa
    38,284
    Re: What is it?
    With a CYA of 80ppm, you should never let the FC get below 6ppm. Once it does, then algae can start to grow. Clearly your FC is much too low. Review the FC/CYA Chart.
    Only 2 things consume FC. The sun and stuff in the water. With a high CYA, the sun is less a factor, so there must be something in the water.
    At this point you likely need to follow the ShockLevelAndMAINTAIN Process to clear up the pool.
    To post larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    May 2014
    Clinton,Iowa
    42
    Re: What is it?
    Can you still swim while SLAMing?
    Sand Filter"
    Model #AC16985
    Clinton, Iowa
    jccams's Avatar
    Dexter, MI
    95
    Re: What is it?
    Yes as long as chlorine levels are at or below shock level that corresponds to your CYA.
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
