Results 1 to 17 of 17
Thread: Motor going out, replace Pump? or just motor?
    Mar 2010
    Dallas, TX
    61
    So my pump motor is going out, my pump is a 2HP Pentair Challenger. The motor is starting to not work well. What I mean by that is that the motor upon start will make a loud whining noise and sometimes simply shut off since I guess it is not turning the impeller. I popped the cap off at the back of the motor to see what happens.
    When I turn it on, sometimes the back part turns and thats when the motor begins to pump. other times it just makes a really high pitch whine and shuts off. If I try to turn it on again it won't even try. So I wait and noticed I hear a click near the motor, which then I am able to try again.
    I don't know if the motor can be fixed, so I was looking at replacing it. then I thought, maybe I should just get a new pump altogether if I am going to spend a couple of hundred dollars anyway.
    I need advise as to wether the motor symptoms are something that can be fixed or if I should replace the motor and how to pick a new motor.
    I took a pic of the tag on the motor for reference.
    thanks.
    38,371
    Re: Motor going out, replace Pump? or just motor?
    Please add your pool details to your signature as described HERE as it will help us help you.
    Is the pump itself in good shape?
    Do you nee the big 2HP pump for some reason?
    Mar 2010
    Dallas, TX
    61
    This is actually my parents pool, who they just moved in.
    Its a free form in ground concrete pool with a spa attached. My guess is its about 20k gallons, they have a Pentair Challenger 2hp, and a pentair filter. Not sure of its DE or cartridge.
    I don't know if the 2hp pump was original from the builder...we found an old pump that was in the garage...
    upon moving in they did some tile work and found out they have a serious leak in the pool. there is a big crack in the side of the pool.
    38,371
    With the spa, you likely need the larger pump. I would certainly suggest getting a 2-speed whether you replace just the motor or the entire pump.
    Mar 2010
    Dallas, TX
    61
    I read on other similar threads that its the capacitor...how hard is it to replace this? and do these symptoms sound like its the capacitor?
    how do I know which one I need and do I need to remove the pump to change this part?
    thanks.
    38,371
    Replacing a capacitor is not hard, but could be potentially very dangerous if you do not know how to handle and discharge the capacitor. One of them is under that big hump on the motor and the other would be inside the rear cover.
    The other possibility is that the centrifugal switch is dirty and needs cleaning, but I think less likely.
    The click you are hearing could be a thermal overload protection switch. But I don't think a bad cap or switch would cause overheating.
    Can you easily turn the motor by hand?
    Mar 2010
    Dallas, TX
    61
    I removed the cap from the back of the motor and can turn the motor with my fingers...I am just not sure if the fix is as easy as replacing the cap...which is this something that I have to remove and try and get it at leslies? or is it cheaper to order online?
    I don't want to replace it and lose all the time in waiting for the replacement capacitor for it to not work....
    Jul 2011
    Perrysburg, OH
    88
    It could certainly be just the capacitor. If you have an electrical supply store nearby or even a Grainger, bring it in to them and you could probably get a replacement on the spot for less than $20. If that doesn't work it might be your motor bearings are going bad and putting extra strain on the cap for starting. If the new cap doesn't fix it you'll need to check/change the bearings or get a new motor most likely.
    16 x 32 inground vinyl pool (21000 gallons) (new liner installed 2014)
    Hayward max flo pump w/ 1 HP AO Smith motor (new motor 2014)
    Hayward C1200 cartridge filter (new 2014)
    Hayward H150 heater
    Mar 2010
    Dallas, TX
    61
    I will try to remove the capacitor tonight and try that route first...
    Do I check both of them/replace both of them? my pump has the big hump on top that is the capacitor inside...
    if this route doesn't work...How can I make sure I order the correct motor replacement...I am unsure of what info from the label I need...
    thanks.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    The replacement motor is an AO Smith/Century B855. For a two speed motor it would be the B2984. Or if you want a built in timer the B2984T.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Mar 2010
    Dallas, TX
    61
    removed the capacitor...tested it...and the needle moved a little less than halfway and then back to zero...
    does that mean the capacitor is good?
    Mar 2010
    Dallas, TX
    61
    so I brought the capacitor to grangier and they checked it and it is good...is the big capacitor on top(the one I removed) the run capacitor?
    I tried to remove the back cover of the motor to see if I check if there is another capacitor there but couldn't open it up. is this where the start capacitor is located?
    Quote Originally Posted by sargent View Post
    sergent, according to my motor, the service factor is 2.20 HP, and the one you recommend the B855 from what I found is a 2HP with Service Factor of 1.1HP....
    are you sure this is what I need to get?
    38,371
    Yours is a 2HP motor with a 1.1 SF making the SFHP = 2.2
    I am not exactly sure which cap is the run cap and which is the start cap, I think the one in the back cover is the start cap.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    If you look at the table on this page, the 346201/CH11-N1-2A, which is what is on your motor nameplate, has the B855 as the replacement motor. It is a 2HP with a service factor of 1.1. Like Jason said, that makes a SFHP of 2 x 1.1 = 2.2. That is exactly what your motor is.
    I would actually recommend the two speed motor because in the long run you will save money by running on low except when you are vacuuming or running the spa. But if you do that, you will also have to have a way to switch between high and low.
    By the way, the high pitch whine makes me think it is probably bearings that are beginning to wear out rather than the capacitor.
    Oct 2013
    Chapin, SC
    1,141
    My pump went tango uniform Saturday afternoon. A repair guy finally got here yesterday to replace the motor. Had an estimate to replace the motor for $333. When he got the seal plate removed he found cracks where the mount bolts are. That would be another $75 or so. So now we're up over $400. I can get a single speed for just $450 something. He recommended getting a Intelleflo 3hp VS pump or possibly a $200 less expensive new Superflow 1hp VS . I read reviews that suggested the Intelliflo VS would give somewhat better energy savings that could pay for itself in about 18 months or even less. So, I ordered the 3HP Intelliflo VS. It should be here Tuesday so in the mean time, I'm putting bleach in my pool.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    The Superflo probably would not be large enough for the original poster. The Intelliflo would be large enough, but at around $900 or more it is much more expensive than replacing his motor and seals. We are talking a $500 difference (maybe more) between that and a two speed motor. I believe Dallas has relatively low electricity rates, so it is unlikely the more expensive pump would be worthwhile unless he wanted it for something other than energy savings.
    However, if he is replacing the whole pump with a two speed pump, a likely choice that would give him flow close to what he has now would be the Whisperflo WFDS-6 or WFDS-28. That will cost him over $700, so it is only a couple hundred dollars more to go to the variable speed.
    Mar 2013
    22
    I know those Challenger Pumps don't digest a lot of the debris that make it though the pump basket and you can't reach the impeller through the housing with your fingers, so if I have an opportunity to replace them, I do it unless you don't have issues with little leaves and palm hairs there.
    2013 20x40 Vinyl Ingound Pool. 30K Gallons. Hayward Aqua Rite Chlorine Generator. Hayward C-3030 Cartridge Filter. 1.5 HP Pentair Pump. Pentair Magic Stream II Deck Jets. Pool Automation=Allen-Bradley PLC 5/04. TF-100 Test Kit.
