Thread: Coverstar Deckmount Pool cover fabric pulled free from one side
    Aug 2014
    Acworth, Ga.
    2
    Hello All, I have a 9yr old 16X36' automatic Deckmount Coverstar pool cover (it's on top of the pool deck) that I found on Monday morning completely open down the left side. It has pulled free from the guide rail and is submerged in the water. The other side is also showing signs of stress and has started to pull free of its guide railing at places. There is too much weight for the booms and motor to handle to try to retract the cover as is and since its loose on one side, removing the water on top of it is not an option. I thought about removing the smaller non-motor boom, and letting it free float in the water and try to retract it but one side is still anchored the the deck and releasing it may bend the rails. Called Coverstar last year for rope replacement. Extremely expensive quote along with horror stories on internet provided motivation to DIY the job... sorry Coverstar fans.
    The cover and side webbing that slides in the guides are not ripped yet so re-installing it should be somewhat easy. My main problem is retracting it for a end of year family pool party on 8/17. ANY help will be greatly appreciated.
    - Les Richards
    Mar 2013
    Rochester, NY
    86
    Re: Coverstar Deckmount Pool cover fabric pulled free from one side
    Hi! I have a coverstar cover and remember seeing some info here on DIY. Good luck!!
    Happy reading.
    http://www.troublefreepool.com/threa...star-autocover
    http://x.havuz.org/viewtopic.php?t=8375
    http://www.automaticswimmingpoolcove...one-FC1002.htm
    This video maybe helpful too!! http://www.youtube.com/watch?v=SLXKa-QQlCA
    18' x 38' IG Vinyl 21K
    1.5 Hp Hayward pump
    Double main drain, 4 returns
    Rheem heater
    18' x 6' Sun ledge, Automatic Cover, Interfab Extreme Slide
    Aug 2014
    Acworth, Ga.
    2
    Rmonile, thanks for your reply but my rope(s) didn't break. The fabric pulled out of the guide rails on one side. I was able to open it slightly and close it again because the ropes are still intact. Any experience with a side coming loose? I'm at a loss
    IG vinyl lined, 16X34X8' pool using a sand filter,
    Pentair SWG control system with a single speed 1hp pump.
    Coverstar automatic pool cover is around 8-9yrs old.
    A Polaris 360 cleaner keeps the bottom somewhat clean.
