Thread: What do I do with my weir flap on my skimmer?
    bobgio's Avatar
    Sep 2013
    Niagara Falls, Ontario, Canada
    14
    I have an inground pool in a very cold climate and I will be lowering my water below my returns. What do I do my weir flap on my skimmer? Do I just leave it or remove it and if so how does it come off?
    Thanks
    Bob G, 18x36, 21000 Litre, inground, starite system 3 cartridge filter, raypac heater
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: What do I do with my weir flap on my skimmer?
    It should have two little pinch in plastic retainer clips. Just remove it if you like and maybe replace it with a skimmer face plug.
    38,284
    The 2 skimmers I had were not that easy to remove the weir ... you had to lay down and use a screw driver from inside the skimmer. I am not sure what is recommended though as I have never winterized.
    Jun 2010
    Toronto, ON. Canada
    230
    When the PB closed ours last year, he shoved an empty gallon of algaecide into the skimmer from the flap, keeping it open. Maybe you can do that?
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    Jan 2013
    Cleveland, OH
    70
    I've never worried about mine in 18 years, just left it there (as normal) after pool winterized...never a problem.
    20K gal, vinyl, 1 HP Challenger 2-spd pump, 300 lb sand filter, Raypak 266K BTU, 45M stenner pumpin' bleach
    Jul 2014
    Berks County, PA
    206
    I have never removed the weir during the winter...it shouldn't be a problem to leave it on.
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
