Thread: What plugs for return jets? What a mystery!
    bobgio's Avatar
    Sep 2013
    Niagara Falls, Ontario, Canada
    14
    I own an inground vinyl lined pool and will be winterizing it for the first time this year. What I am confused and frustrated about is the various opinions as to what type of plug to use in the 1.5 inch return jets for the winter…oh yeah…I live in Niagara Falls, Canada.
    I have seen several people here have recommended the Hayward sp1022c type plug. However, all the reading I have done suggest that these are meant for concrete pools.
    I know the abs threaded plugs exist and I have also seen these by Feherguard:
    Please help…I want the best product for max resuts.
    Bob G, 18x36, 21000 Litre, inground, starite system 3 cartridge filter, raypac heater
    bobgio's Avatar
    Sep 2013
    14
    Winterizing my Raypac (Rheem) heater?
    I Merged your there together to keep the full story in one place. You will get much better answers that way. -Karmabiker
    I have an inground pool in a very cold climate and I will be lowering my water below my returns.
    Question has to do with my raypac heater...it is new and have no idea what step 2 and 3 are referring to. Any help with further instructions or diagrams would be helpful. Also how do I know if I have an ASME heater?
    1. Turn off gas valve, manual gas valve, and electrical
    supply to the heater.
    2. Open drain plug located on the inlet/outlet header,
    (under water pipes). Remove the heat exchanger
    inspection panel on the side opposite water piping
    to gain access to the drain plug on the return header.
    Open drain plug on return header.
    3. For ASME Heaters only: Disconnect compression
    fittings from the pressure switch and return header
    that connects to the 1/4" copper tube and allow the
    tube to drain.
    Jul 2014
    Berks County, PA
    206
    Re: What plugs for return jets? What a mystery!
    With my heater, I just drain the water out of it, then disconnect the two plumbing lines, let that drain, then reconnect them but loosely. As to return line plugs, mine are not threaded - it is simply the end of the pipe that is cut off on an angle slightly in from the edge of the plaster, so I use rubber plugs with a wing nut. They expand and seal the pipe opening.
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
