Thread: Just Ran My Numbers
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Just Ran My Numbers
    I've been reading on here quite a bit and have been puck free since the end of June. I've had some ups and downs, but I think I have things dialed in. My CYA is high, but I've chosen not to bring that down because I have some maintenance to be done at the end of the season that will require me to lower the pool level. So here are my numbers. Btw, pool is clear, looks as good as it has all season.
    FC: 8.5
    CC: 0
    PH: 8
    TA: 100
    CH: 150
    CYA: 80 (tested full and half strength)
    Now, should I mess with the ph? Honestly I've never seen it high before. I do know target on FCC is 9 and I will be adding bleach later today. I've been holding around 9 by adding @ 64oz of 8.25% bleach/day. Is there anything else I should be doing or just stay the course?
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    38,540
    Re: Just Ran My Numbers
    Try to keep the pH in the 7s at all times.
    It is likely rising more now because you are not using acidic tablets which would lower the pH.
