Thread: Algae on grout
    Jul 2013
    Placentia CA
    5
    Algae on grout
    I have been maintaining the chemical balance for over a year now with pretty good success thanks to this site and a TFT kit except for 1 recurring issue, green and black algae on the tile grout at the top of the pool. About a month ago we scrubbed it all away and now its back. Any suggestions?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Algae on grout
    It's probably because it doesn't stay submerged in the chlorinated water. I get a little bit also.
    Aug 2010
    Dallas, TX
    4,052
    Re: Algae on grout
    Do us a favor and add your pool specifics to your signature.
    Do you use an SWG for chlorine source? If so, are you targeting FC of 3? I had this problem when I kept my FC at 3, and found that FC was dropping below the minimum, especially at the water line. I have bumped my target up to 5-6, and haven't had the problem since.
    May 2013
    Deep East Texas
    79
    Re: Algae on grout
    Try changing your return jet pattern toward problem areas.
    In ground 25,000 gallon - vinyl liner - Sand filter - residential pool
    Also maintain two commercial 190,000 gallon competitive indoor bromine facilities -9x Sand filters
    Jul 2013
    Placentia CA
    5
    Re: Algae on grout
    I will try to bump up the levels to 5-6. Thanks.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Algae on grout
    A couple of canon ball jumps every week will help get the chlorine splashed up on the tile above the waterline. I have a 6 year old that does it for me
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
