Results 1 to 15 of 15
Thread: Hello All
    CusePool's Avatar
    Aug 2014
    Friendswood, TX
    91
    Hello All
    I just joined TFP, but have been browsing for some time. I'm located in Friendswood, TX. Looks like there are lots of Texas and Houston area people here!
    We're in the process of building our first pool. I've never owned a pool before (grew up with one, but never owned/operated one).
    We signed our contract in mid-May, dug June 20, and I figure we are probably 3 to 4 weeks away from being complete. We've got our landscaping plants purchased and awaiting installation once construction is done. I'm ready to not have a clay mud pit outside my backdoor!!
    The next step will be a very basic outdoor kitchen - really more just a grill island. I look forward to pestering people here with questions once we start the equipment up!
    38,514
    Re: Hello All
    Welcome to TFP!!! and congratulations on getting a pool
    Now is the time to start reading Pool School to learn about the chemistry, begin with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    And of course get one of the Recommended Test Kits ordered so you have it before the pool is filled.
    Please add your pool details to your signature as described HERE as it will help us help you in the future.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hello All
    Welcome to the forum fellow Texan!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hello All
    Welcome,
    We can always use more Texans.
    Essential Links:
    CusePool's Avatar
    Aug 2014
    Friendswood, TX
    91
    Re: Hello All
    Thanks for the links. I'm ordering a test kit today!
    Thanks for the welcome. I'll start up a construction thread and post some pictures when I get a chance. I am really crossing my fingers that we'll be done in the next 2 weeks.
    CusePool's Avatar
    Aug 2014
    Friendswood, TX
    91
    Re: Hello All
    I just got my TF-100 test kit. Is there any reason to test my fill water before we fill the pool up? What would I be test for? Calcium hardness, pH, something else?
    ~18,000 IG/Spa chlorine, Blue Granite Pebblesheen
    Hayward 1.5hp 2-speed Tri-Star Pump, 525sqft Swimclear filter, Polaris 280 cleaner
    400K BTU Heater, LED Lights, PS8 Automation
    Build thread: http://www.troublefreepool.com/threa...s-Houston-area
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hello All
    Quote Originally Posted by CusePool View Post
    Heck yes! Test your fill water for two reasons. First it gets you used to performing the tests with confidence. Second it lets you know where your water chemistry is starting out. Test the fill water for pH, CH, TA. Not really necessary to test for CYA (there should be none in all sources other than pool water) and FC/CC should be very minimal compared to pool levels. Make sure you test water that has not been softened. If you're using your own well or city water, collect cold water after it has been running for several minutes in a clean container.
    Isolated Spa - 345 Gallons
    CusePool's Avatar
    Aug 2014
    Friendswood, TX
    91
    Re: Hello All
    OK thanks, I'll try it this weekend.
    CusePool's Avatar
    Aug 2014
    Friendswood, TX
    91
    Re: Hello All
    OK I tested the fill water. Here's what I got:
    Chlorine = zero (no color change in the tester)
    pH = 7.2
    CH = 125 ppm
    TA = 90
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hello All
    "The stars at night are big and bright ~clap - clap - clap - clap~ deep in the heart of Texas"
    Those numbers look pretty dog gone good Is the fill water municipal or well water?
    You're done SLAMing when:
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Hello All
    Is there anyone in Texas that does not have a pool???
    Welcome!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jul 2014
    Bastrop, Louisiana
    199
    Re: Hello All
    The Governor, he has two pools.
    Greetings CusePool.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    Re: Hello All
    Some people here do not have pools, but IMO in general, those folks came from up North and are not yet considered to be Texans.
    Lots and lots and lots of reasons for Texans to have a pool. Below is just a few examples, there are many more, and its a family forum, so.... for starters.
    1. It's very hot here in Spring Time .
    2. Its very very hot here in summer.
    3. It's very very very hot here in late summer - such as now.
    4. Us Texans are generally friendly folks and we like to invite our friends to have some pool fun.
    5. We like to cook out and need a pool in order to do a proper Texan cook out - with friends of course.
    Quote Originally Posted by northrn View Post
    Welcome!
    Divin Dave,
    CusePool's Avatar
    Aug 2014
    Friendswood, TX
    91
    Re: Hello All
    Quote Originally Posted by Butterfly View Post
    That is city water. I even tested it after coming through the hose I will use for the fill.
    Welcome!
    Just me, for another week or so, then it will be everybody! Thanks for the welcome.
    Quote Originally Posted by one_knight4u View Post
    Greetings CusePool.
    Thanks!
    Quote Originally Posted by Divin Dave View Post
    Concur with all. We should have a good two plus months of hot swimming weather left by the time we get done.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Hello All
    Very jealous of your swim season! Mine is coming to a close within the next 3-4 weeks. I will have to live vicariously through Texans. Hope your install goes well!
