Thread: Borates testing after boric acid addition
    Jun 2014
    Edmond, Oklahoma
    42
    The thread on adding Borax+Muriatic acid recommends waiting 48 hrs before testing for borates. I have, however, decided to go the boric acid route.
    Got my shipment from Duda Diesel last night. I have a question about testing once I add the acid. Can I test immediately, or is it similar to adding them with borax, i.e., I'd need to wait 48 hrs for them to register on the Lamotte strips?
    I am a relatively new owner and am still learning how my pool reacts with chemical additions, vs. the expected results from Poolmath. I have overshot a couple of chemical changes and have since taken to making my adjustments in a couple of smaller stages rather than all at once. I usually add half of what I expect to need for a given chemical, test, then determine if I want to go with the second half as is, or adjust my second addition slightly.
    Pool math says I need roughly 29 lbs. of boric acid to get to 50 ppm for my pool. Ideally, I'd like to add in 2 stages as well.
    Would I need to add, wait 48 hrs. then test? Or since I'm adding boric acid instead of Borax, will a test be accurate once the crystals have dissolved and the pool recirculates for a couple of hrs.?
    12,500 gallon, in-ground Grecian Rectangle (vinyl liner). Installed June 2014. Sand filter, SWG for chlorination. TF-100 test kit.
    Located in Edmond, OK
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Borates testing after boric acid addition
    Once it's in solution it should show up on the test strips. I'd add about 1/2, measure, then add the rest.
    Jun 2014
    Edmond, Oklahoma
    42
    Thanks bobo. Is the pool swimmable once it's dissolved? Or do I need to run the pump a couple hours before my daughter and her friends get in?
    38,369
    You should always run the pump to mix all chemicals at least 30 minutes before swimming.
