Results 1 to 9 of 9
Thread: Vacation Time
    DSdiver's Avatar
    Sep 2013
    South Eastern Wisconsin
    28
    Vacation Time
    Does anyone have any suggestions on taking vacation time from your pool. It's been 3 years now and we are going on vacation for our first time away from our pool for a week. We have an auto cover and will close this and put the pump on. My question is do I need to do anything else for a week away I don't want to come back to a green pool our loose the crystal clear water we have enjoyed all summer. Does any one have any thoughts,
    FC 5
    CC .5
    TA 210
    PH 7.5
    CYA 60/70
    Calcium 220
    Salt 3400 PPM
    20x40 IG vinyl lined 34,100 gallon/Hayward filter EcoStar model SP 3400 VSP/Hayward filter(sand) model S310T2 flow rate 98GPM/RayPack gas heater model 266 266,000BTU/Aqua Plus Automation and chlorination with Hayward Turbo Cell T-Cell-15/Hayward universal color logic light/ Delta UV filter/4 return lines 2 skimmers and dual main drains/Auto cover/ Pool is 3 years old. TFT test kit XL speedstir.
    38,290
    Re: Vacation Time
    Since you have a SWG, there is really not much you need to do differently. Just lower the pH into the lower 7s (since the SWG will make it rise; although depends on how often you are finding you need to add acid to lower it normally), put the cover on, and enjoy your vacation.
    Jul 2013
    Lelystad, The Netherlands
    60
    Re: Vacation Time
    Do you really intend to run the pump 24/7 for a week ?!
    Do you have a firnedly neighbor who can take a visual look at the pool 2 or 3 times the week?
    40000 liter in ground vinyl pool with SWG : http://www.troublefreepool.com/threa...he-Netherlands
    DSdiver's Avatar
    Sep 2013
    28
    Re: Vacation Time
    My pump is VS and run 24/7 different % all the time. So yes we would run the pump.
    Cool thanks for the help
    38,290
    Re: Vacation Time
    Wait, you are running the pump 24/7? That is way overkill.
    Have you read this Pool School article: http://www.troublefreepool.com/conte...-pump-run-time
    Aug 2010
    Dallas, TX
    4,052
    Re: Vacation Time
    Some of us with large pools need to run 24x7, and with a VF or VS and SWG this can be a good thing. His 34,000 gallon pool is pretty big, and depending on his SWG and pump, he may have to run all the time just as I do. My pump typically says it is using 350 watts. I just looked, right now it's running 430 watts, 1800 RPM, and 29 GPM. This is a little higher than normal. I do lower the run time when we move into fall and winter.
    I lower my pH to 7.2 and leave. I don't cover the pool, or do anything any differently than I do when I am at home. That's why I have the SWG.
    38,290
    Re: Vacation Time
    Why do you need to run 24/7? Seems like that would only be required if your SWG was operating at 100% already.
    Sure with the VS pump, the electrical costs are lower ... but not running for 12 hours would save 50% of the power cost. Easiest way to save money on power is to turn off the pump.
    Aug 2010
    Dallas, TX
    4,052
    Re: Vacation Time
    When I installed the VF, I determined what the optimum RPM/GPM would be in regards to power use vs water clarity. At 350 watts, it's running about 1200 RPM (IIRC) and is really in the sweet spot. I believe the higher power usage currently is due to some changes I made in the eyeballs, but even at 450, it's not terrible usage. The SWG is running 22 hours per day at 90%. It was simply easier to let it go ahead and run 24/7 with it set up this way than to go through a bunch of trouble fiddling with the pump's programming and the SWG to find the absolute optimum run time by shaving 2 hours off.
    Another issue is I only have returns in the shallow end and one skimmer that's not really in the optimum location. Also, I have lots of very large trees. To keep the pool clear of leaves, the longer run time helps to catch them in the skimmer before they go to the bottom. I guess not as much thought went into where returns and skimmer(s) should go when they built this pool. Currently I have slit eyeballs in 3 of the returns, and a PoolSkim on the 4th, to assist with the problem. It seems to be working.
    If I ran the pump for 12 hours, I would have to use more power and a higher GPM. Twice the power does not equal twice the GPM, so really there is no savings. In fact, it could cost me more.
    38,290
    Re: Vacation Time
    Interesting. Certainly sounds like you have some things in your pool that point toward the need for the long run time (like a nearly maxed out SWG, high debris loads, and not ideal return/skimmer locations). In most cases reducing the run time to 12 hours (or much less) should not actually require an increase in pump speed and thus no increase in power cost.
