Thread: Will a waterfall help as a pool cooler?
    greenhorn31's Avatar
    Aug 2014
    Katy, TX
    3
    First post, I'd like to thank whoever is responsible for this forum it is certainly priceless, just wished I had found 5 years ago when I owned my first pool.
    We have moved from VA to Houston TX and are getting pricing for our new IG pool. Now that we are in Texas I'm concerned with the water temps I don't like a hot pool and I've researched all the pool coolers, my question is will the waterfalls or shear descents act a a cooler to any degree? Secondly I like the little aerator I think it's less obtrusive on the pools view , I'm thinking it may be advantageous to get the piping installed during the build with it's own valve and connect it to my controller as it's own water feature. I appreciate any thoughts on this, thanks in advance.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Will a waterfall help as a pool cooler?
    It might help some, but a fountain with a mist would probally do a better job due to the evaporation cooling effect. Solar? You can run it at night for cooling.
    30,432
    Welcome to the forum. Whatever pool cooler you end up with, think of them as an evaporator rather than simply transferring the heat from pool water to air.
    It is the evaporative process (day or night) which makes pool coolers so VERY effective (and inexpensive)
    mas985's Avatar
    Pleasanton, CA
    11,742
    A big box fan blowing across the pool would help too.
    Mark
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,024
    This aerator works nicely. I would recommend at least 2 of them (and maybe more, depending on if you have any shade or not).
    Quote Originally Posted by greenhorn31 View Post
    Divin Dave,
