Thread: Slamming question.
    Aug 2010
    Charleston, South Carolina
    77
    Slamming question.
    I've had some problems with some small black spots in my pool. If I scrub them off with a wire brush there's still a faint spot there and if the Chlorine ever gets low they just come back. So my plan is to scrub everything real good and start SLAMMING. But we've had a ton of rain so my CYA is a little low. Should I bring that up to 70 first and then SLAM? Also my salt is almost at the point where I need to add another bag. But I'm thinking of holding off on that since I'm getting ready to add so much Liquid Chlorine. Here are my test results.
    FC - 2.5
    PH 7.8
    TA - 80
    CH - 240
    CYA - 50
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    30,426
    Re: Slamming question.
    Leave your CYA alone when you start the SLAM.
    Add salt when the SLAM is complete.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    You should adjust your pH if you intend to SLAM.
    Edit: duraleigh answered first.
