Thread: Anyone know what's in API Revive?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,773
    Just curious. The product claims to remove phosphates (which normally don't matter) but also to remove copper and iron to 2ppm (a very specific claim) and to be great for wellwater. Sounds like a flocking agent.
    Snake oil or science, guys?
    Tried to get the Msds here but am not a dealer http://www.apiwater.com/dealer-login/msds/
    Thanks for any thoughts or the Msds if you can get it. Not desperate but always interested in products that claim to remove metals as its the holy grail for those with wells!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Anyone know what's in API Revive?
    No MSDS we could find. See Revive & EZ Pool. Not much info unfortunately.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,773
    I decided to write and ask for the Msds. That might give me a clue.
    While I'm not likely to escape a lifelong dependency on sequestrant, in my case it might make sense periodically (eg every few years) to reduce the subsequent high levels of spent phosphates and if it can reduce the metal load somewhat at the same time then that would mean less sequestrant would theoretically be required for the next season.
    I did open clean, cold, and early (it snowed the next day in April but had a fair amount of staining. So the chlorine held despite high spent phosphates, but the sequestering didn't!
    Do orthophosphates ever break down or reduce on their own?
    Helpful Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    Orthophosphates do not break down and are only removed by water dilution, but they will be taken up by any bacteria or algae that grow and incorporated into organic phosphates including the DNA backbone and ADP/ATP energy molecules.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,773
    Thanks, that's what I suspected
    Helpful Links:
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,773
    Btw, the mfg did send me the Msds...but the proprietary active ingredient was not named, so I will not be trying the product ;(
    Helpful Links:
