Results 1 to 9 of 9
Thread: What do i need here?
    Jun 2007
    Charleston, SC
    33
    Every time i vacuum my pool floor clean, shortly after it has very fine yellow/brown particles that have dumped themselves back onto the floor via the wall ports. I vacuum, then backwash, then turn the pump back on filter, and if you go over and look at the jets, you can actually see the discolored water and small particles being dumped back into the pool - very frustrating! Where can i find a vacuum or pump that i can use to just suck that stuff off the floor and directly into the backyard, completely bypassing the pool's filter? Any thoughts?
    35+ year old 16 x 30 oval, depth 4 ft to 8 ft, in ground concrete pool approx 17,000 gallons-using BBB method
    30,426
    Re: What do i need here?
    What positions or "settings" do you have on the valve on your filter?
    Jun 2007
    Charleston, SC
    33
    When I vacuum, the valve is set to filter, then I turn it off and take the vacuum out of the skimmer and turn it on backwash for a few minutes. Then i turn it off and set it to filter again for normal use. that's when the junk flushes back into the pool. I think i've tried vacuuming the scum in waste mode too, but i remember that it still seems to come back in through the wall jets...
    30,426
    After you "backwash", put the filter on "rinse" for about 60 seconds or so. That should eliminate or minimize the blowback into your pool.
    Jun 2007
    Charleston, SC
    33
    hmmm, never used the rinse mode before. I'll try that this evening! Thanks! Also, where can i find instructions to open the sand filter? Is it easy to do?
    Butterfly's Avatar
    South Carolina
    10,045
    Hi dolemite77,
    You might also want to google a copy of the owner's manual.
    You're done SLAMing when:
    Jun 2007
    Charleston, SC
    33
    so for this situation, are these the steps?
    vacuum to waste
    backwash
    rinse
    or do you rinse then backwash?
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    dolemite77
    Hello this is the standard procedure.
    vacuum on filter,
    backwash till water is clear,
    rinse for 20 or 30 seconds,
    If you want you can vacuum to waste, but you will lose a lot of water.
    Also you don't have to backwash everytime you vacuum, [in fact it's better if you don't] only when the pressure gauge goes 8 to 10 psi above what it is just after back washing
    Happy Swims Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Jun 2007
    Charleston, SC
    33
    thanks for all your help!
