Thread: HotSpring Vanguard LED Light quit working! Any ideas?
    SirBrowning's Avatar
    Jun 2013
    Northwest Florida
    19
    I have a 6 year old HotSpring Vanguard hot tub and just recently the light (Which I believe is LED) quit working. When I push the button to turn it on the little light symbol shows up on the LCD Screen but it does not illuminate. BUT when I flip the breaker and reset the hot tub, the lights work again and turn on/off without any issue. So it appears to be some sort of electrical issue, any ideas?
    Thanks!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: HotSpring Vanguard LED Light quit working! Any ideas?
    That's a mysterious one. I would inspect the wiring itself from the power supply to the light in the tub. See if there are any loose connections, frayed wires, etc.
    It also could be a problem with the power distribution board or transformer for the low voltage portion of your power.
    Isolated Spa - 345 Gallons
