Thread: Red vs. Black overpressure valve.
    I currently own a Letro Legend cleaner and one of my little ones broke the housing coming out of the wall. Forced to take a trip to the pool store and, despite me telling them what I owned, said that the Polaris housing would suffice. Low and behold, my red overpressure valve wouldn't fit into the Polaris housing so I took a trip back and found it less expensive to simply purchase the overpressure valve that fits the new housing. The color of this one is black and I was told - no problem, no difference. Now, all is hooked up and the cleaner is working just fine BUT there is a trace about of water exiting the black valve as if it is over-pressured. No debris in my cleaner so I assume it is designed to open at a lower pressure but can't seem to find anything to support that.
    2 questions - 1. Is there a difference between the red and black over-pressure valves and 2. Do I need to buy a new housing with a red valve that matches the one that was supplied with my unit?
    TIA
    steve
    15 K gal/gunnite, 600 gal attached SPA, Hayward: ProLogic, ColorLogic LED, Super II pumps, 400k BTU heater, StarClear cartridge filter for, SwimClear cartridge filter . Pentaire: booster
    http://www.troublefreepool.com/detai...l?hilit=corpus
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Red vs. Black overpressure valve.
    Bump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Looks to be an E25 valve.
    http://www.pentairpool.com/pdfs/LegendOM.pdf
    They don't specify spring strength. I'm thinking if you have dark fittings you'd want the dark valve and vice versa.
