Results 1 to 10 of 10
Thread: Hayward DE filter
    Virginia Beach, VA
    13
    Hayward DE filter
    I've been getting a lot of DE in the pool and whenever I vacuum it up I see clouds of DE from the return. It's been gradually getting worse. Thoughts on whether it's time to replace the grids or if it's something else?
    38,237
    Re: Hayward DE filter
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you in the future.
    Sounds like it is time to open up the filter and inspect things ....
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    +1 on opening up the filter. I's time to inspect to see IF it's the grids. If no damage is detected it would be a good time to soak them overnight and do a through cleaning.
    Solar Blanket, Well Water, Borax Added. 68
    Virginia Beach, VA
    13
    Yo Frog, soak them in what? I'll kiss them if it'll make the pool cleaner.....
    Jul 2013
    Gilbert, Az
    116
    this was happening to mine and my grids were cracked
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    javaverses's Avatar
    Aug 2014
    Pearland, TX
    49
    I just soaked my Hayward DE filter grid for the first time, and found the information here to be helpful for the general cleaning part:
    http://www.troublefreepool.com/threa...aning-Tutorial
    And for the soaking go here:
    Also if you soak them be sure you have something you can totally submerse them in like a plastic trash can. I didn't think about that until I got to that step and had to hunt around and clean out our recycling can! Also be prepared to get wet & dirty, it's a messy job!
    Java - Learning that an ounce of prevention is worth a pound of cure!- Houston Tx - 22,000 gallon IG gunite pool running a DE Hayward filter DE-4800 (48SQFT 96 GPM), Hayward Vari-flo multi-port valve 715XR60, Pump - Century Centurion 0-177215-04 1hp. Polaris 9400 Sport Robotic Pool Cleaner. 1 skimmer, 1 main drain, a pool light, diving board. Age of pool &equipment unknown, pool age est. ~ 20-30 yrs, equipment probably newer.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I couldn't have linked it better if I did it myself Javaverses
    javaverses's Avatar
    Aug 2014
    Pearland, TX
    49
    Thanks kiss4afrog, just trying to give back some of the help you guys gave me!
    Virginia Beach, VA
    13
    Quote Originally Posted by javaverses View Post
    Thx for the insight. Will play with it tomorrow and respond back with results. I don't see any amount of buildup in the grids which is why I suspected it was time to replace them. I've been in the house for 6 years and suspect the pool is at least 12 years old. Not sure of the age of the grids, but wondered about the lifespan. They are expensive to replace biut found these on Amazon:
    http://smile.amazon.com/Hayward-Pro-...rd+pool+filter
    I'd hate to pay retail at Leslie's...
    38,237
    There are many eBay sellers for less than that. I got mine for around 130 delivered.
