Results 1 to 10 of 10
Thread: new pool filter
    Jun 2013
    MA
    104
    new pool filter
    I'm looking to ditch the cartridge filter that came with my pool. I have been dealing with a green pool for 3 weeks now and mine just isn't clearing it. I have been keeping the chlorine level high. Currently I am SLAMMING it. 3 days of 24/7 running my filter and it hasn't changed a bit. Any recommendations on a good filter for a 18x48 Ultra frame intex pool that won't cost an arm and a leg but will clear my pool?
    18x48 ultra frame AG Intex pool 6423 gallons
    Krystal Clear Sand Filter Pump Model SF70110
    Test kit - TF-100
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    new pool filter
    So exactly what hasn't changed ? Your filter isn't going to rid or kill the algae. All the filter is going to do is filter out the dead algae. I've seen the same filter do the job on intex pools.
    SLAMing the pool correctly is going kill the algae.
    Can you post up a full set of test results and what test kit you got them with. 😎
    Jeff
    Jun 2013
    MA
    104
    Re: new pool filter
    I use the TF-100
    FC 17
    CC .5
    PH 7.8
    Calcium 50
    TA 100
    CYA 40
    Well a little bit has changed the bottom isn't as green. It's more the water that doesn't look like it's clearing as quick as I'd like. I just assumed if I got a better filter it would clear quicker. I know the ones that come with the pools aren't big enough from what I'm told.
    Test kit - TF-100
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: new pool filter
    You just said it. It's not clearing as quick as you like. The pool will clear, you just have to be patient. It's a marathon not a sprint.
    Your test results look good. Maintain the shock level as best you can. That will speed the process. Your PH is invalid due to the high FC level.
    There was a thread where the OP was having your same problem. Let me see if I can find it as they were given advice on helping the filter out. 😎
    Jeff
    Jun 2013
    MA
    104
    Re: new pool filter
    Thank you... I'm more in the rush so I don't have to run the filter 24/7 anymore.
    Test kit - TF-100
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    new pool filter
    Ok here we go. http://www.troublefreepool.com/showpost.php?p=691356. Take a look at post # 33. You need to run filter 24/7 regardless. 😎
    Jeff
    Jun 2013
    MA
    104
    Re: new pool filter
    So what your saying is whether it is green or not I have to run it 24/7? I always did it 6 hours a day like the directions told me. Maybe that's why I ended up in this mess. Thank you for the link.
    Test kit - TF-100
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: new pool filter
    Only while your SLAMing run it 24/7. Otherwise run it normally. You got algae because your FC levels dropped below your min. 😎
    Jeff
    Jun 2013
    MA
    104
    Re: new pool filter
    got it. I'll be patient. Save my money on the new filter for now and play the waiting game and watch it clear up on it's own.
    Test kit - TF-100
    Jun 2013
    MA
    104
    Re: new pool filter
    We are now on over a week of running my filter 24/7 and slamming it. Pool is still the same light green and cloudy. Levels are still all the same as they were prior. Any other suggestions on what I can do to clear this cloudiness up?
    Test kit - TF-100
