Thread: First time closing pool
    Victor's Avatar
    Girard, OH
    38
    Hello all, I just have some questions on the right equipment needed to close my pool. The last 2 years the builder has done it for me, this year I want to give it a go. When he closed it last year, he used the solid threaded PVC plugs to close returns, has anyone tried the duck bill plugs, or the all rubber plugs with wing nut in center. Any pro and cons to either? Also going to be using air compressor, I've been reading to keep it under 10 psi. Any other concerns?
    IG, steel walled vinyl liner, approx. 18000 gal. swg ( Hayward salt system), gas heated, with 250 lb sand filter and 1.5 horse pump.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: First time closing pool
    I've used PVC plugs and compression (wing nut center) plugs. Both seem to be fine but I prefer the PVC plugs with an o-ring for the returns, use the compression fittings for the skimmer bucket.
    I've only used a shop vac for blowing out lines and admittedly it's been a few years since I helped someone close their pool. Also my first year doing my own pool...
    Isolated Spa - 345 Gallons
    Jul 2014
    Berks County, PA
    206
    I use the rubber plugs and have never had a problem. The trick is to really watch them close while you are blowing the lines out (BTW - 10 lbs. on the compressor is fine) and make sure that there are no bubbles coming out. I find the best way to get them in, since you will be putting them in while the air pressure is coming through the lines, is to really lean over the coping and push them in pretty hard, then start tightening them up. I have two return lines - once the one is plugged and no air bubbles coming out anymore, I do the other one. Once that is plugged, then I go to the skimmer. For that I have a double plug (both rubber). The one goes all the way down and plugs the drain line, the other plugs the skimmer pipe.
    12,000 gal. Anthony IG pool; 3 ft. shallow end to 6 ft. deep end; Built 1989; Renovated July 2014 using a 10-part unexposed quartz plaster aggregate of 3 S-grade Blue, 3 S-grade Gray, 2 T-grade Blue, 2 T-grade Gray; Apollo VA-52 DE Filter; Hayward SP-2607X10 Super Pump 1-HP Single Speed; Jandy AE-Ti Heat Pump; Taylor K-2006 Test Kit
    Victor's Avatar
    Girard, OH
    38
    Thanks guys wish me luck!!
