Thread: Numbers good but need PH help???
    Jul 2012
    Oklahoma City
    72
    I am adding 1/2 gal of acid (MA) every 4-7 days to maintain 7.5-7.8, any ideas what to do?
    FC 3.5
    CC 0
    PH 8.2 (currently, will be adding another 1/2 gal MA)
    CH 300
    TA 80
    CYA 65
    Salt 3800
    CYA could be a little higher but I am worried to add more conditioner and CYA get too high. I am running pump 12hr/day with SWG at 50%.
    Water has been clear since initial filling.
    Thanks
    IG gunite Edmond, OK(OKC), 18x36 freeform ~20K, 4-8' deep, Pentair equip, (2) 3hp VS+ pump, 520 cart filter, 3 LED, Easytouch8, ItellichlorIC40 SWG, Polaris 3900 cleaner, Spa 8'x18"raised, 20' raised bond beam 2 sheers, Stonescape Tahoe Blue quartz plaster, TF-100 kit.
    Feb. 25, 2014 dig started, May 24, 2014 filled.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Numbers good but need PH help???
    Your plaster is only three months old? I would test and adjust a little more often so it doesn't get so high. Looking at your signature you have a lot of things happening to aerate the pool in addition to the curing gunite. pH is going to rise.
    Support the site
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    What he said, test daily or every other. If you are reading 8.2 you are at the top of the range and might actually be a little or a lot higher. Since you don't know how high it is you should make an adjustment, let it mix for 30 minutes and test again to make sure it's come down to your target.
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2012
    Oklahoma City
    72
    Thanks for the feedback! I updated sig profile and yes the plaster is new. I will check more often and add smaller amounts of MA too.
    How long does this go on with new plaster??
    Thanks again.
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Flatlander View Post
    Thanks again.
    Check out the Pool School article about starting up new plaster.
    Support the site
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You can expect it to be using a lot of acid the first 6 to 12 months. Smaller more frequent additions would be easier on the plaster.
