Results 1 to 9 of 9
Thread: First attempt at SLAMing green pool - Advice always welcome!
    Aug 2014
    Winchester, VA
    5
    Brand new to the BBB concept, but have been spending countless hours reading up on the forum. I went to Leslie Pools and picked up their Total Poolcare DPD Test kit, made by Taylor.... I think it is similar to the Taylor 2006.
    Here's what I'm starting with:
    FC: 0
    TC: 0
    pH: 7.2
    Base Demand: 3
    TA: 110
    CH: 190
    CYA: 30
    Based on the pool calculator, I've dropped four 121oz containers of 8.25% bleach. I'm adding just a little bit of CYA to bring that up as well, targeting more around 40 (have it in a sock tied around an empty floating chloring container right now). I'll retest 2-3 times a day to keep the chlorine level up and add as needed.
    Other info on the pool:
    ~20,000 kidney shaped inground
    Pump: Hayward Star Clearplus Cartridge Filter, Model C751
    Additional: Smartpool 4i robot pool cleaner
    This all started a few weeks back when lightning knocked out the power, then we had a number of 100+ degree days with neither of us home (shift work - firefighter/paramedics). He's out of town for 4 days, and I'm hoping to get a knock on this mess!
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: First attempt at SLAMing green pool - Advice always welcome!
    Welcome to the forum!
    You're on the right track, but the test kit is missing one critical component. You need the FAS-DPD test, not the DPD test. Leslie's is notorious for saying "Don't worry, it's the same thing."
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    You can order the FAS/DPD test kit to make your K2005 into the K2006
    Support the site
    Aug 2014
    Winchester, VA
    5
    Yep, that was the response I got. Noted, I'll get the add on kit so I can get the proper readings
    Aug 2014
    Winchester, VA
    5
    Alright, now that I have the proper kit...
    As of this morning:
    Fc 1.5
    Tc 1
    pH 7.2
    TA 12
    CYA 55
    Added 4 121 oz 8.25 bleach containers this morning. Will retest in 2 hours to see where I'm at!
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Linds View Post
    As of this morning:
    Fc 1.5
    Tc 1
    pH 7.2
    TA 12
    CYA 55
    Should that Tc really be CC?
    FC + CC = TC
    We generally ignore the TC number as FC & CC are what we deal with.
    Interesting to note that the earlier (I assume pool store tested) CYA was 30 but you came up with 50. That is how pool stores mess up folks pools. Remember, with a CYA this high stay away from the solid forms of chlorine unless you have a SWCG or are planning to add one soon.
    It would help us if you would add the following information to your signature
    • The size of your pool in gallons
    • If your pool is an AG (above ground) or IG (in ground)
    • If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    • The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    • If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    • Date of pool build/install, particularly important if less then a year old.
    • What kind/model of water test kit you are using
    • Other significant accessories or options, such as a spa , SWG, or cleaner
    Keep up the good work, you are moving in the right direction.
    Support the site
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,084
    I'd like to start off by welcoming you to the forum. I'm sure with a bit of work on your part, you will shortly have the same sparkling water you see others here with.
    Given the water color and your test results, a SLAM is in order. I would start by reading the ABC's of Pool Water Chemistry. This will help you learn the basic taught on the forum. From there the video below explains the SLAM process in full detail.
    You're on the right track with ordering your test kit and finding this site.........please feel free to continue to ask questions if needed. WE LOVE TO HELP!
    Aug 2014
    Winchester, VA
    5
    Whoops, yes the TC should have been CC
    ~20,000 gallon inground, kidney shaped pool. Plaster/Tile. Hayward Star Clearplus Cartridge Filter, Model C751 plus Smartpool 4i robot pool cleaner. Unknown install date (5+ years?). Using Taylor 2006 Kit
    Aug 2014
    Winchester, VA
    5
    Thanks for the video!
    2 hours into the SLAM and my FC dropped to 17, so I added 90oz per the pool calculator. This is acceptable based on the pool chem, but I'm aiming for maintaining 20. I'm not quite sure what kind of algae is growing, so I thought I'd aim a little high?
    A little nervous doing this, but hoping for the best! I'll be closely monitoring the pool all day today and tomorrow, so hoping to keep the levels right on target and see some sort of improvement!
