Thread: Automation for Intelliflo VR and Intellichlor
    Jul 2014
    Tempe, arizona
    19
    I have a Itelliflo VR with a Intellichlor SWG all new
    We are fire up the Salt water system today, but the electrician is encounter a electrical problem with the SWG. Needs to be on a timer box so as to fire up when the Intelliflo VR fires up.
    The geniuses at Pentair didn't make the system integrated unless you purchase the Easytouch or the sun touch systems add ons.
    Now the $64,000 dollars question.
    I don't want it wired to a flipping timer box. I want everything to play and integrate together.
    Would you or do any of you have either the easy touch or the sun touch?
    Don't really care about being able to use my iPhone, just want proper connections and stuff to start up properly...
    Thanks.
    21,000
    In ground
    Intelliflo VS
    Side suction Robot
    38,251
    Re: Automation for Intelliflo VR and Intellichlor
    The simplest would be to get a current sensing relay on the power supply to the pump that would then close and provide power to the SWG. So the SWG will only get power when the pump is running. You would use the pump to control the speeds and times and the SWG to control the % output.
    There are a few discussions about this setup on the forum if you do a search.
