Results 1 to 12 of 12
Thread: Is a gallon of muriatic acid per week ok?
    Jun 2014
    New, England
    66
    I've been using about a gallon of muriatic acid per week to control pH and I'm just wondering if this is ok. I measure pH everyday, but I usually add the acid once per week, right after I go through my full weekly battery of tests on Saturday.
    Saturday morning, I'll get done with my testing and almost consistently find the pH up around 8.2. I'll add a gallon of muriatic acid, and test again a few hours later to find it at 7.2. The reason I add once per week is because I really like to limit my exposure to the stuff and only want to deal with it once per week.
    However, I'm just wondering if it seems normal for my size IGP to be using a gallon per week.
    FC = 5
    CC = 0
    TC = 5
    pH = 7.5
    TA = 100
    CH = 250
    CYA = 40
    Salt = 2000
    Borate = 31.6
    26k Gal. 18' x 38' Gunite/White Plaster Roman style in-ground pool, straight Clorox bleach sanitizer, DE filter, TF-100 Test Kit, Taylor Salt Test Kit, Borate Drop test
    Mar 2011
    Houston, Texas
    413
    Re: Is a gallon of muriatic acid per week ok?
    If it's a new pool that's normal--at least that's about what I used for the first few months.
    Now I use about a quart a week, but I have a SWG and lots of aeration.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    PoolMath say that for each gallon of 31.45% acid in a 23k gal pool at TA=100, TA will decrease by 22. Just wondering if you are seeing a this level of TA decrease each week? Also wondering what TA your fill water is?
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Jun 2014
    New, England
    66
    Quote Originally Posted by HouTex View Post
    Hi HouTex. Yep, I forgot to mention this is a brand new pool finished mid-June of this year. I was thinking the rise in pH might have something to do with the new plaster, but wasn't sure.
    Quote Originally Posted by epro05 View Post
    epro5: I have not tried measuring TA directly after dumping in the gallon of muriatic acid. I've only measured pH about three hours after and then remeasured TA the following week with the rest of my testing battery.
    I'm going to try testing TA directly after adding muriatic acid this coming weekend though and see what drop I get. I'm also interested in the TA of my fill water. I'll try that as well.
    Jun 2011
    Long Beach, CA
    2,778
    You should be adding the acid more often, do not let the pH rise above 7.8 as you are risking scaling when the pH is above 7.8. With time the acid demand will slow down as the plaster cures.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by ping View Post
    I was going to say that. Smaller additions several times a week are much better on the pool and equipment than huge fluctuations once a week.
    Support the site
    Jan 2013
    Houston, TX
    1,079
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    May 2014
    Mesa, Arizona
    180
    Quote Originally Posted by tim5055 View Post
    Sound advice!
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
    Jun 2013
    Dunwoody, GA
    74
    I needed to lower PH so I bought some muriatic acid and started reading up on how to use it, I was frankly scared after reading the instructions people posted about using it, went to HD and got some PH down, don't care if it costs a couple of extra bucks
    so I have 2 jugs of MA in North Atlanta (dunwoody) if anyone is interested
    Tallman Monterey (fiberglass), 16'x33', 11500 gallons, 480 sq/ft, Depth: 3' - 5' 6", Salt Water, TF-100, Pentair pump, sand filter, Easy Touch Control System, SWG
    Aug 2010
    Dallas, TX
    4,052
    That's my pool's diet with new plaster, but my pool is twice as big.
    Jun 2014
    Oslo
    120
    Quote Originally Posted by WWells View Post
    You are better off with the muriatic acid since the PH down add sulfates in the water and in long run you might regret it. The hydrochloric acid is normally found even in human stomac so do not hesitate to use it. It is better for the pool and cheaper too.
    South of France inground rectangular 17k pool - ruber membrane. Sliding dome, black thermal blanket covering 75% of the pool surface. Aqualux 3/4Hp pump, glass media sand filter, Zodillac robot, 110W UV-c lamp, Hayward brominator, Caliente 12kW heat pump.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    I bet my comment is one of the ones you are referring to. I use and like 31.45 because it minimizes the volume I have to use, but yes, it's strong stuff.
    I believe Home Depot near me carries a weaker one. Lowe's also has a second bottle I have never read the label of. Look for a more dilute concentration than 31.45...like 15ish.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
