Results 1 to 7 of 7
Thread: Dolphin DX4 Power Supplies
    Jul 2011
    Broken Arrow, OK (Tulsa)
    294
    We are in our pool's third season, and have had the power supply for our Dolphin DX4 replaced three times.
    And now...the power supply has died again. Plug it in...no lights...nothing, no matter what buttons are pressed. (Yes...checked the outlet, and there's power there).
    The power supply that died was just replaced in the March/April timeframe. I will be contacting the pool supply store to see if it's still under warranty or not.
    Is this something that's a common problem with these pool cleaners? I'm happy when the robot works...but frustrated the power supply dies as often as what I'm seeing. Do these things not like to be kept outside? Am I supposed to bring it in when it rains or something?
    Needless to say, when this unit gets replaced (may be sooner rather than later!) there's no way I'll get a Dolphin robot cleaner.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Dolphin DX4 Power Supplies
    If you haven't already done so, you may want to use the TFP Search function and search for Dophin Power Supply. There's several interesting posts to read.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jul 2011
    294
    Gtemkin...yes, I see there are some other posts dealing with the same issue.
    So...from what I'm able to gather, it is a known problem that water gets inside the power supply and shorts it out. But...if one goes to the Maytronics site, there are no covers available for them. And, seriously...we're supposed to bring them inside to avoid rain?
    I haven't heard back from my pool store yet, but there may be a Polaris 9450/9550 ordered soon....
    Aug 2010
    Dallas, TX
    4,052
    My Dolphin 4 lost 3 power supplies in just a matter of 2 or 3 months after the purchase. The last one has lasted 3 years though.
    Maytronics gives conflicting info on the power supply and weather. In many places, they say they are weatherproof. But then in the manual it says to not leave it in the rain.
    If you leave it in the sun, the power button starts to dry rot after a few years.
    I have a cover for my Weber kettle. I'm going to take it down and see if it fits over the cart for my Dolphin today.
    Jul 2011
    294
    My pool store is going to check if the power supply I just replaced at the beginning of this season is still under warranty or not. I'll report back here once I learn the answer.
    Don't know if you solved this problem. This happened to us finally after TOTAL disassembly I strap from goggles was stuck in the track wheel, box was not turning on due to a mechanism that will not let it begin when this happens m
    Jul 2011
    294
    Maytronics said they wouldn't warranty the power supply that was replaced this spring because the robot is out of warranty. Ended up buying a new power supply from inyopool, as it was a whole lot less than replacing the robot. Also picked up a grill cover I will use to cover the caddy/power supply...hopefully the cover will keep this one working for at least a couple more years.
