Thread: SLAMing but forgot to lower PH
    Aug 2013
    Long Island, NY
    32
    Added chlorine to start SLAM process, but forgot to lower PH! Can I just add enough acid to reduce to 7.2 based on the 7.6 reading I got before I added the chlorine?
    10k gal, AG, cartridge filter, installed August 2012, Taylor K-2006
    38,237
    Re: SLAMing but forgot to lower PH
    That should be fine, make sure you have your TA entered as well as that affects the dosing calculations.
    Aug 2013
    Long Island, NY
    32
    Ok thanks. Could I test TA after adding chlorine or will that be inaccurate as well?
    38,237
    You can test TA.
