Results 1 to 7 of 7
Thread: Handling 14% Chlorine
    Kes's Avatar
    Apr 2010
    Worcester UK
    46
    For several years I have used Tesco's thin bleach as a chlorine source: with a content of 1.5% sodium hypochlorite it is easy and very safe to handle, and cheap too. However it isn't so good when I need to shock, as I do now: I would need a trailer-full of bottles. So I have bought some 14-15% s/h in five litre containers (about 1.3 US gallons). For shocking I need to use a 5 litre dose.
    I am rather wary about how I should handle this. With care, yes. Should I decant and dilute first? Pour directly into the pool? I don't really know how potent this stuff is - yet. Any advice appreciated.
    11,000 Imp galls inground hopper 15' x 35', Delifol liner (vinyl), sand filter, Abrisud Classic cover, Palintest 315C test kit
    Jun 2014
    Boca Raton, FL
    101
    Re: Handling 14% Chlorine
    We routinely use 12.5% bleach in US. Reasonable care needs to be exercised as it will ruin most anything of color, like cloths, furniture, and car interiors if spilled.
    When transporting and storing, ensure lids are tight and well sealing. (ive bleached the back of 2 cars due to not doing this)
    Place jugs in trunk well lined with plastic / visqueen to catch any inadvertent drips
    If jugs have handles, use bungee cords etc. to secure loose jugs in car for transport.
    Try buying bleach in case quantities as they will transport better.
    Wear suitable clothing when pouring bleach into pool. Swim suits work rather well. Jeans do not work well as they seem to be magnets for bleach stains.
    16x32 DiamondBrite kidney, 12,500 gal. (circa 1985) 3/4hp Hayward SII, Harmsco BF84, Taylor K-2006, Hayward SwimPure Plus / Tcell-15
    Boca Roton, Fl. USA.
    prior 17k gal. vinyl, Sand filter
    22,551
    15% is pretty potent stuff, but not extremely so. We don't take any more special precautions with 15% than we would with 8.25%. If you're concerned with splashing, eye protection might be a good idea and old clothes that you don't care about.
    Just pour it into the pool directly in front of a running return. Just lower the bottle close to the pool surface to help prevent splashing.
    Jun 2014
    Boca Raton, FL
    101
    To dispense quantities you mention, ~5 litres, I also use a cheap plastic watering can (sprinkle head removed) which allows me to dilute 50/50 with pool water. They seem to hold 8-10 liters. It seems I can pour this around the side of the pool using the watering can, with minimal splashing.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Just don't wear any clothing you value.
    Kes's Avatar
    Apr 2010
    Worcester UK
    46
    Thanks everyone.
    Aug 2011
    Cochranville, PA
    228
    I use my dirty close when handling my bleach. They are the clothes that have no worth. Most are stained with paint or grease. The bleach splash adds character. I think what you have going for you is that one container is a full dose. So you don't have to measure it out into another container. Just have to learn to pour it slow enough it doesn't gulp and fast enough it doesn't drip down the front of the container. When done pouring you need to make sure you rinse off what drips down the front of the container. You might think about a rubbermaid tub for transporting just in case it splashes or leaks it is contained.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
