Results 1 to 7 of 7
Thread: Polaris 380 died - Rebuild? Replace? or buy something new?
    SirBrowning's Avatar
    Jun 2013
    Northwest Florida
    19
    I just installed a brand new booster pump 6 months ago, and today I noticed the Polaris no longer working well. I took it out of the pool and wheels are cracked,t he housing cracked, the jets are cracked, etc. It is 12 years old, and has never had any rebuild and I am wondering with the age would it be worth a rebuild or just buying a brand new one.
    So what would you guys recommend? Rebuild? New Polaris 380? Or are there better options for the money?
    My Pool is a 20x40 33k gallons. Biggest issue I have are leaves and some dirt and bugs, with a little bit of sand here and there.
    Thanks in advance!
    Mar 2014
    Northern CA
    18
    Re: Polaris 380 died - Rebuild? Replace? or buy something new?
    I would cut my losses, go robot and never look back. So happy I did that very same thing. No more hoping and praying the Polaris gets the gunk. The robot just does it. No drama, just a clean pool every time.
    14,000 gal IG Plaster, Intelliflo VS pump with Pentair CCP 320 filter cartridge, Dohenys AWD and Stenner pump w/15gal tank .
    Jun 2013
    Northwest Florida
    19
    Well I hate just wasting a brand new booster pump. Plus I like the fact that i can just setup the timer to kick on that booster pump and have it automatically clean every day. With robotic cleaners from what I understand you have to manually drop the thing in the pool, let it run for a set time, then remember to pull it back out and wind everything back up. I just like the set it and forget it of the Polaris cleaners.
    I have also bee told that I should "downgrade" to the Polaris 280, as it can use the booster pump AND it performs as well (if not better) than the 380. They also said that the 280 will last longer and need very little maintenance compared to the 380. Any thoughts on that?
    Apr 2009
    Northern Virgina
    55
    You could look into the cost of an overhaul kit, but if you decide to replace it, I think you would be better off with the 280. Based on what I've read here on the TFP forum, it's got a less complicated design than the 380, so it's more reliable. I finally replaced my 20-year-old 180 with a 280 a couple of years ago and have been very pleased with the increased cleaning performance (two jets vs one) and reliability.
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I'm a happy 380 owner, but I've never had to buy a rebuild kit. Bought a couple of tune-up kits. Those are not too expensive; rebuild kits are pricey and that may be what you need, if you need to replace the wheels.
    If your 380 repair costs start getting close to 50% of the cost of a new 280, I'd go for a new 280. I'd look on Craigslist, though, before I spent bust-out retail on a new 280. Might even find a used 380 with the parts you need.
    Re. 280 v. 380 - I've heard the 280 will suck up the neighbor's cat, if you're not careful....
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Oct 2012
    Houston, TX
    29
    I have a 20x40 40k gallon pool and my 280 does a great job... just wish it would make it into the hot tub...
    40,000 gallon ig gunite, Pentair Challanger Century Centurion 2.2 HP Pump, FNS 60 DE filter, Polaris 280, Century Centurion 3/4 HP Booster Pump, Attached ig spa - 1HP Centurion pump - Dual non functioning blowers
    Jun 2013
    Northwest Florida
    19
    Well, I ended up just ordering the Rebuild Kit, as it seems the Rebuild kit for the 380 has essentially an entire brand new 380, the only thing I will have to reuse is the Inner Frame with the serial number on it. That cost $207 shipped, vs the cheapest I could find the Polaris 280 was $454 shipped. So as of right now that seems to be the best, most economical option. My 380 was 12 years old and never been repaired, rebuilt, or tuned-up (besides tire and tail sponge replacements) so I would think it held up pretty good.
    Thanks for all the suggestions! Will let you know how the rebuild goes.
