Results 1 to 8 of 8
Thread: I'm now the proud owner of a green pool
    Jun 2007
    MA
    165
    I have my first algae issue. We have had alot of rain I have semi neglected my pool this last 2 weeks. I just vacumed it threw in a gallon of bleach. I need to buy more tonight after I pick up the kids. I'll test water and report those. I tested last week numbers were fine. The pool looks decent now just cloudy but 98% of the green is gone.
    Cheryl
    14X42 Intex Ultra Frame
    Re: I'm now the proud owner of a green pool
    If you catch algae early it is often very easy to kill off. But ignore it for too long and it becomes a major project.
    Jun 2007
    MA
    165
    tested any advice to rid algae
    [Merged posts:Butterfly]
    My numbers
    ph 7.5
    TA 1.1 I think something is wrong took 11 drops for color to change
    TC 3.5
    CC 1
    fast chlorine 6.5
    Cheryl
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: tested any advice to rid algae
    Read up at Pool School There is lots of helpful information there that will help your CYA reading, that will determine what you shock your pool at to get rid of your algae.
    It would be helpful to know how many gallons your pool hold, what its made of (Vinyl, gunite, fiberglass) Your filter type and pump size etc. You can add those to your signature so you dont have to type it all the time.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Butterfly's Avatar
    South Carolina
    10,045
    What is your CYA?
    With CC of 1, you need to shock your pool. There is an article in Pool School on Defeating Algae & on Shocking Your Pool.
    Please add your pool & equipment info in your signature.
    To do this, go to User Control Panel (top, left, under TFP Logo), Select Profile, then Edit Signature. Thanks!
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by my4boys2002
    My numbers
    ph 7.5
    TC 3.5
    CC 1
    fast chlorine 6.5
    fast chlorine? not sure what this is?
    TA 1.1 (11 drops) means your TA is 110....
    CYA reading?
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    My numbers
    ph 7.5
    TC 3.5
    CC 1
    fast chlorine 6.5
    11 drops times 10 is 110 and that is ok for Alkalinity...that is about where mine is.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Feb 2008
    Northwest Indiana
    902
    Quote Originally Posted by cubbybeave08
    My numbers
    ph 7.5
    TC 3.5
    CC 1
    fast chlorine 6.5
    PM... that is what I get for not reading to the end of a thread...You beat me to it...
    Beave
