Results 1 to 7 of 7
Thread: 5 year old hayward heater
    Aug 2014
    Pittsburgh
    4
    Swim Pro by Hayward Heater ABG1001 after 5 years of great performance has started repeatedly firing up then flame goes off and cold air blows. noticed repeated pop of flame coming on over and over. Similar replacement is $677 on Amazon. Should I just be glad I got 5 good years and drop the $677 for a replacement? Or does repair make any sense for a 5 year old unit.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: 5 year old hayward heater
    I would check the gas jet nozzles and make sure they are clean. Spiders like to make webs in them.
    Mark
    ps0303's Avatar
    Jul 2011
    FL
    3,709
    Yes give the burners and the orifices a good cleaning and see what happens. Use something soft like a pipe cleaner on the orifices.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Aug 2014
    Pittsburgh
    4
    mas985 and ps0303.....thanks for the suggestion. sounds like a great idea. once i open it up is it pretty self explanatory? do i need to do and dis-assembly inside to get to the spots to clean??
    Aug 2014
    Pittsburgh
    4
    update......i took it apart which was fun and educational. but i find that water is dripping down onto the burners. which i assume means the heat ex-changer is damaged? so do i stop now and order a new heater? or is it possible to repair the leak?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Yea, it looks like you need a new ex-changer. I don't think they are repairable.
    Mark
    Aug 2014
    Pittsburgh
    4
    new exchanger $380.......whole new heater $677.......heater is 5 years old so i am going with the new heater. thanks all for the education! i now understand how a pool heater works and what the insides look like and how to clean the burners on my new heater
