Thread: Hypothetical- Whats the oldest sand filter youve seen that was still functional?
    People,
    Well, that it- title is my question. My pool's filter is from 1981. Ive been thinking of changing it, but need advice as to if I REALLY need it. (water does take days and days to finally clear up).
    Thanks, people.
    16,000 gal in ground, marcite. FL.
    Jun 2007
    New Jersey
    653
    Re: Hypothetical- Whats the oldest sand filter youve seen that was still functional?
    Quote Originally Posted by noquacks View Post
    People,
    Thanks, people.
    I replaced our second steel filter on my old 1946 pool with a Lomart Stainless steel sand filter the year after I got my driver's licence (1972). I never changed the sand and it remained in continuous service until 2002 when the pool itself was decommissioned because I sold the land it was on. It was still keeping things perfectly clear. If I still had that pool, I believe it would be working today. The cast iron and sheet steel filters used through the 1960's were good for only about 15 years, so I doubt you will find anything older than about 1970 when I believe the stainless steel filters started.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Its a Tagelus, TA60. If that helps determine what I got......thanks
    A few years ago we replaced an old steel tank sand filter from the late 60s. The filter was still worked just fine, but the main valve was completely shot and the tank was heavily rusted. From what I could find out they stopped selling the repair parts around 2003, so replacement was the only option.
    Sand filters take a while to clear up the water, that is just the way they are, nothing to do with being old.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Wow, and I thought my 1980s stainless steel PacFab 50 that I just replaced was old...
    Isolated Spa - 345 Gallons
    38,524
    So what exactly are you trying to clear up? Sand filters are slower, but there are ways to speed up the process by using DE. But, if your issue is chemistry related, then the type and age of filter does not matter.
