Thread: Water fall
    Dec 2013
    San Antonio, TX
    38
    Water fall
    Starting to notice little bit of algae that has a green color on parts of the moss rock water fall, not bad. Is this common for moss rock water falls? We have no issues with algae in the pool. Should I be concerned? Best way to get rid a of it? Brush it?
    One more question, we just built and filled in Mach, best way to rid the white line of calcium that has started to show on tile? Any chemical to help with brushing it?
    San Antonio TX 14K Gal in ground free form jandy vs pump with DE filter polaris cleaning system with auto feed chlorinater, JandyJXi400N natural gas heater
    Dec 2013
    San Antonio, TX
    38
    Re: Water fall
    Can anyone help with this?
    30,431
    Re: Water fall
    Everything about water chemistry begins with test results. Can you post a current, complete set?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Water fall
    If your water chemistry can handle the addition of muratic acid then that can be diluted and used to clean the tile line. My pool had extreme effervescence which included little volcanoes of calcium on many grout lines. I picked up a Purity Pool OS Out Spot Stain Remover and used it to apply full strength muratic acid to the spots and slowly remove them. This is not a scrub brush, but can only be used to apply the acid to specific locations.
    Support the site
