Thread: Urgent sand filter help needed regarding installation!
    lhall120's Avatar
    Aug 2014
    North Branch, MI
    3
    I am about to use a shotgun to riddle my pool with bullets. Please note I am new to troublefreepool, have had my first pool for just one month, and I have searched for the answer to my question and believe it's out there but the replies are likely over my not-so-handy head. If you are kind enough to reply, please answer as if you're explaining to a kindergartner so that I can fully understand. Thanks so much.
    I have a metal frame Intex 12' x 30" pool, with no skimmer. I just purchased an Intex 14" Sand Filter Pump (2900 Gallons). I could have sworn that, upon reading the reviews on Amazon, someone posted that they purchased this sand filter to use with their 12x30 Intex pool. Now I'm concerned that I can't use this with my pool. So, I have (at least) 4 problems/questions:
    1. The pool, nor the new sand filter, came with a plunger valve. Is the plunger valve necessary?
    2. The pool inlet is just a 1.25" plastic neck coming out from the liner (no threading). The instructions in the sand filter manual show a threaded connector that comes out of the liner at the pool inlet. Not included, nor do I have it.
    3. The threaded end of the pump/filter hose is much larger than the pool inlet.
    4. Did I get the wrong Intex filter? Is there a way to construct an adaptor so this filter will work?
    Thanks SO MUCH for any help you can provide. I'm so frustrated with trying to understand all this, and also with finding by trial and error that what I need to properly run this pool is not clearly indicated in the Intex literature.
    Leslie
    Intex metal frame 12x30; Intex 14" sand filter; Intex wall mount surface skimmer
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Urgent sand filter help needed regarding installation!
    You need the Intex hose conversion adapter kit to connect it to your pool. A plunger valve is handy for shutting off water flow when needed, but you could get by without it if you can't find any.
    Love TFP? Become a
    TFP Supporter!
    lhall120's Avatar
    Aug 2014
    North Branch, MI
    3
    Thank you so much for the info!
    Leslie
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    You could also cut out the smaller connectors on the pool and use the larger fittings that should have come with the new pump.
    Just use an exacto knife and take your time. It won't leak or tear if you do it properly.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    Oh sorry, just reread that you didn't get the larger inlet and return with your pump. Funny, I thought they were always included. I've purchased 2 sand filter pumps over the years and they always came with them. I have a couple of extra sets lying around. Too bad you're not local, I'd let you have them.
    Pentair IC40 SWG
