Thread: Cell life question
    Jul 2013
    East Texas
    11
    Cell life question
    What has a bigger impact on the life of a cell, run time or what percent the cell is run at? IE: is it better to run 3 hours a day at 60% or 6 hours a day at 30%? These are just numbers pulled out of thin air, but hopefully will explain the question better.
    Re: Cell life question
    Cell life is measured in hours energized. It doesn't matter if that is 1 hour at 100% or 10 hours at 10%, both result in one hour energized and use the same amount of cell lifetime. Your example is the same, both combinations result in 1.8 hours energized, so use up the same portion of the cell lifetime.
    Jul 2013
    East Texas
    11
    Ok, that's confusing. What is the formula for calculating hour energized?
    Time energized = <hours pump is running> * <percentage> / 100
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    489
    for your cell life they both equal the same amount of wear
    3x60=180 6x30=180
    but running the pump longer will filter pool better at the cost of more pump run time/electricity
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
