Thread: Flow sensing pump shutoff
    schurtj's Avatar
    Jan 2014
    Reynoldsburg, Ohio
    20
    Recently I have been having a reoccurring nightmare where I am at work, and a line on my pump system comes apart allowing the pump to dump 22,000 gallons of water next to my house and basement!
    Is there some sort of flow sensor that would be able to sense the lack of flow, and turn off my pump?
    22,750 gallon in-ground Vinyl Liner (1 main, 2 skimmers, 5 returns) 16x38 from 4' to 9'
    1hp A.O. Smith coupled to Hayward Superpump 52gpm
    300 lb Sta-Rite Crystal-Flo sand filter
    Hayward Comfortzone gas heater
    Manual Pool Vacuum (yes seriously)
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Flow sensing pump shutoff
    Seems like a better solution would be to fix the pipe. I would not want to rely on anything to shut off the motor in a timely manner.
    Mark
