Results 1 to 18 of 18
Thread: Generic Kreepy Krauly...
    mark-o's Avatar
    Jun 2014
    Bossier Louisiana
    18
    Question Generic Kreepy Krauly...
    Anyone have one? I have always just vacuumed my pool over the years the old way. I just ordered a "Generic" on Amazon that has decent reviews, just wondering if any of y'all have tried one.
    16 x 36 inground vinyl w/ covered steps. 9 1/2 ft deep end w/ diving board. 27,000 gal.
    PacFab Challenger 1 1/2 hp 2 speed pump, Pureflo 300 lb sand filter, Pentair chlorine feeder
    1 skimmer, 1 main drain, 3 return lines and NO LEAKS "knock on wood" LOL.
    Jun 2011
    Austin, Texas
    206
    Re: Generic Kreepy Krauly...
    I'm exactly in your boat and am very interested in this exact model you're looking at. I haven't bought one though. One thing I worry is if it winds up getting stuck on the steps in my pool.
    Also, the generic ad doesn't seem to mention anything about the ability to regulate the amount of suction from the skimmer that gets delivered to the unit, but the brand name one does mention that it comes with a way to regulate that.
    18 foot diameter, 52" tall above ground Cornelius pool, with vinyl liner, and resin wall caps.
    Roughly 7600 gallons
    Blue Wave "Sandman" Sand filter/pump, model NE6150. Pump is 1 HP
    Intex SWG, model # 54601E
    mark-o's Avatar
    Jun 2014
    Bossier Louisiana
    18
    Well... FedEx delivered it today, ordered on Sat. so pretty fast from Commerce California. 2 parts to snap on, add weights to hose put hose together and drop in pool. So far it's doing better than expected but I need 3 more hose sections to get full coverage. As for the steps I've watched it for 2 hours and it won't even try to climb on the steps on its on, just turns and moves on. I was worried about it hanging up on steps and ladder on deep end but it just bumps and goes. Looks like a brush on the steps and the "Generic Kreepy" will do the rest. 80 bucks to my door and I like it. WIN WIN!!!
    Just saw this. I had a Barracuda Alpha (same basic concept as the Kreepy Krauly) that worked for years in my 16 x 32 inground pool. I kept buying replacement hoses as they developed leaks and had to zip tie a piece of styrofoam to the top when the float allowed water in and stopped floating. When Costco had a deal on a Kleen Machine robotic cleaner for $300 I bought it and it is a big improvement. The robotic cleaner is so much easier to put in and take out of the pool compared to all the hose sections. It also does a better job and keeps the debris out of the filter.
    I think I've had it for 3-4 years and it just today stopped working so I am possibly looking to buy a replacement robotic cleaner. At $80, the generic Kreepy Krauly is a great deal. If you get tired of it, get a robotic cleaner. You will not be sorry.
    16x32 Inground Gunite Pool, 1965, renovated, epoxy painted.
    Hayward Ecostar Pump
    6' Conical Franciscan Woodworks Teak Hot tub
    Riles_J's Avatar
    Nashville, TN
    218
    Just received my Generic Kreepy as well. My Jacuzzi Tracker (thePoolCleaner) finally bit the bullet and I needed something fast and cheap. So far this thing works pretty good. It tends to not want to visit the shallow end as much I would like, but some adjustment may be needed. It cleans good, scoots up the slopes on my deep end well and has been keeping the pool looking good. I am pleased so far.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Sep 2014
    Loganville, Ga
    6
    Link to this generic Kreepy?
    1999 build, 18x36 Vinyl lined IG pool (7.5'/3' depths), approximately 25k gallons, Hayward 1.5HP pump w/ Hayward s-244T Sand Filter, Dolphin DX4 cleaner.
    Riles_J's Avatar
    Nashville, TN
    218
    Sep 2014
    Sharpsburg, GA
    7
    I have this same Cleaner, it does get hung up on my pool steps now and then. No on the step itself but infront as the hose gets in the opening to the steps and doesnt allow it to turn. Otherwise it doesnt ok, and I have had to adjust returns and weights to get it to cover different areas. Still have not gotten the perfect adjustments. But for the money it does pretty good.
    Leonard
    Jun 2011
    Austin, Texas
    206
    I'm thinking of getting one, but I see your link is for inground pools only. This version claims to work on inground or above ground:
    http://www.amazon.com/XtremepowerUS-...0454844&sr=1-9
    But the title of the ad says in ground or above ground, while the item details mention in ground only. I wonder which it is.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I have the original Kreepy. It does ok, I guess. It hangs up on my deep end steps every now and then so I can't just leave it running and forget it. I noticed it mainly travels in a figure 8 pattern only so I have to move it around manually with my leaf net pole which is a pain. It doesn't pick up many leaves or giant caterpillars either. Begging for a robotic but also need a good pool cover for the fall due to a gazillion trees. So, having to pick my battle on this one and just stick w the kreepy.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Riles_J's Avatar
    Nashville, TN
    218
    Just a follow up to this post after using this cleaner through the winter. While this cleaner does well with dirt and fines on the bottom once I got to fall/winter this cleaner did not meet my expectations. As the poster above said, this cleaner does not pick up leaves, at least not very well. As such, I will likely return to my pool tracker (aka the pool cleaner) this year. I do not close my pool over the fall/winter and I get tons of leaves so if you have a similar issue this may not be the cleaner for you.
    Riles
    May 2015
    River Falls, WI
    124
    I'm quite tempted for the price to pick one of these generic kreepy's up. My Polaris broke and don't want to shell out for a new one yet.
    Any more updates or other pool owners using these with success?
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in ‘70’s, has 8’ deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Jun 2014
    Youngstown, OH
    175
    I just got the generic one from Amazon.. I actually got the one that says "inground" even though I have an AGP.. They are the same exact ones (someone linked one that said for AGP)..
    Anywho.. I got it today and let it run for about an hour.. It seemed to do good, however, I had a good amount of debris in the center of the pool and it never went in the middle.. It seemed to just keep making laps around the outside.. They say to try numerous things (adjust the return jet, hose, weights, etc).. I didn't try any of that yet..
    If it doesn't eventually do the center of the pool I'll return it..
    How long do you guys let these run for?
    Thanks
    Installed in 2014 - 24' Round x 54" Bliss XL Above Ground Pool 14,090 gallons // Hayward S270T Pro Series 27-Inch 350lb Sand Filter // Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed //
    Installed in 2015 - Hayward H200FDN Natural Guess Heater // K-2006 Test Kit
    Youngstown, OH 44514
    DaneCE's Avatar
    Jul 2011
    VA
    279
    tbird, keep in mind that if you have a strong circulating current that this will effect the random pattern. It might be following the current too much.
    4knights's Avatar
    NE Kansas
    419
    I love mine! It does get stuck on the main drains every now and then but otherwise no issues.
    Works like a champ and I paid around $50.00 on Amazon back in October. Now they are $66
    Best Choice Products® Automatic Swimming Pool Cleaner Vacuum Auto Inground Hover Climb Wall 33ft Hose
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    May 2016
    Brentwood/CA
    1
    DaneCE wrote "... if you have a strong circulating current that this will effect the random pattern. It might be following the current too much."
    I found this and other (what a robotic cleaner might consider) nuisance variables have a great effect on my KK. With only one moving part- the piston or "Flapper", the KK is susceptible to hose length, return jet currents, flow and balance. Where a robotic (geared) cleaner may be able to power through these inputs, the KK is controlled by them: It can be turned away from the hose if it binds against itself or the wall, weight placement has a profound effect on the vacuum seal- and therefore movement, jet currents may push the hose (or worse, the leaf canister) with enough force to keep the KK turning in the same direction. I also found that the leaf canister must be at least TWO hose sections away from the wall in order for the KK to bend the hose past my dedicated suction port.
    It has taken hours of trial and error to find the right combination.
    I think i'm there. So far it is better about the areas where my Polaris F7 would get hung up.
    Oct 2007
    Cedar Hill, TN
    251
    I bought one of them in 2013. The cleaner is fine, the hoses started leaking right away. They split at the seams and were super brittle. I kept them going with glue and gorilla tape for that season, but had to get something new for the next year.
    It was cheaper to get another cleaner with the hoses, than just the hoses by itselfe.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Jun 2011
    New Berlin, WI
    48
    I just bought this to replace my Barracuda that came with the pool, apparently it was missing parts I did not know about and said parts cost almost as much as getting a new unit. So this "generic" guy caught my eye, hopefully it will work just as well as the old one, or at the very least the parts can be interchangeable and make my barracuda usable (it lately would just like to sit there and not move no matter what I would do, clean the filter, etc)
    It should arrive tomorrow! Wish me luck!
