Thread: wiring a pool timer
    Aug 2014
    tampa/Florida
    1
    wiring a pool timer
    I installed a 240V intermatic timer and I have a 120V feed to the timer because the pump is 120V. I have wire the terminals to run the pump at 120V, but the timer box only works as a switch currently, I want to have the timer working, but... The timer switch needs to have 2 lines connected to spin the timer dial because I think it is a 240V switch unit. Can I split the 120V wire and energize the timer or will this cause the timer to get destroyed? Does anyone have any suggestions to make the timer function work?
    Re: wiring a pool timer
    Welcome to TFP!
    The 240 volt version of the timer requires 240 volts to run the timer clock. You either need to wire up a 240 volt supply, or replace the timer clock motor with the 120 volt version. The timer can be setup to run it's clock motor from 240 volts and switch a 120 volt circuit, but it might be simpler to just get a 120 volt timer.
    There isn't any easy way to get 240 volts from a 120 volt circuit. There are ways, but they are more complex/expensive than replacing the clock motor.
